Hey guys,
I just bought myself a freshly built rb30 for a steal up here in Canada. I have a few questions about it however
The motor still has M11 head studs but I think I will need to switch to M12 to be safe. the block is o-ringed with a custom copper gasket so I'm not sure how much head sealing is going to be an issue. Is the upgrade to M12 needed or just recommended?
I'm also looking for 4wd adapter and I can't figure out which one to use. The oil pickup is going to be a pain because I have a trust extended sump. If it's easier I might just switch to a 4wd adapter and new sump from the same manufacturer. That way it will bolt up no problem. What is the best route to go here? I'm planning on running 700-800whp and the car is mostly a track car but I don't think I need a block brace, Is this correct?
I'm running a OS Giken twin plate clutch right now but I'm not sure if it will deal with the torque of an RB30 so I might have to upgrade. Anybody have any experience with the OSG twin on a high power RB30?
I'm not sure if the shop that built the motor has much experience with RB30's. They have built a lot of motors but I'm wondering what kind of mods are needed for circuit work. Opening up oil returns, etc, etc. If a pro RB30 builder is willing to advise on this build I would gladly offer up some money in return and of course not divulge there tips. I know this is unlikely but a guys gotta try.
Here is the mods on the car at the moment (I might be leaving out some)
BNR32
Koyo rad w/ twin electric fans
HKS oil cooler
Tomei cam gears
ATI damper
270/270 10.8 procams
Extensively ported head (Quench pads retained)
Cosworth valve springs
xs engineering throttle seals
HKS bar and plate intercooler
Custom t4 twin scroll manifold with single 60mm tial WG
GT4088r
4" stainless exhaust
Vipec V44
Greddy rail w/ 800cc injectors
x2 bosch 044 with large surge tank and Tomei lift pump
HFS-6 water/meth injection kit with direct port x6
HKS Boost controller EVC 6
HKS SSQV II
OS giken 1-5 gears
ACPT Carbon driveshaft
4.375 diffs
ATS Carbon 1.5 way front diff
Factory rear diff reshimmed
That is all I can think of right now but I'm sure I'm missing a few things.
Thanks in advance for the advice.
Edited by Super_Dude
https://www.sau.com.au/forums/topic/344994-my-rb30-build/
Rob from Rips
http://www.ripsltd.com/
is very generous with his advice although it would be only fair to buy the sump and adaptor from him!
Alternatively you could source them from Dick at
http://www.hytechengines.co.nz/
or there are a couple of Aussie suppliers I believe.
https://www.sau.com.au/forums/topic/344994-my-rb30-build/#findComment-5559477
So I think I'm going to use the Hi octane platinum 4wd adapter/block brace and Hi octane race oil pan.
I'm going to keep the M11 studs but was wondering if there is any stronger options than just the regular ARP studs?
I'm also going to get a new clutch seeing as I'm pretty sure my OS giken twin won't last long. I'm probably just going to wait until a good used triple plate appears in the classifieds.
My GT4088r is also being replaced this winter by a new EFR8374.
I can't wait to drive this thing in the spring.
https://www.sau.com.au/forums/topic/344994-my-rb30-build/#findComment-5560759
regular M11 bolts can handle 600hp, so 'normal' arp studs will be fine, unless youre aiming for 40psi, then there are L19 ARP studs,
but i really think thats overkill.
id be looking at the RIPS gear personally, not to say that there is anything wrong with youre choice
https://www.sau.com.au/forums/topic/344994-my-rb30-build/#findComment-5560973
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
