  • Replies 174
Posted Images
I dont think the price is bad at all.
5500 and you get a crank rods and pistons. If your looking at building a rb30det then your up for alot of that anyway.
Im not interested in the peak power, peak power is for spanking of with your friends with. Look at the area under the curve and see if thats bigger.
Power makes you a hero at the pub, torque makes you a hero at the lights.
This thing will be very nice to drive on the street with heaps of grunt
5,500 + Block machining, which isnt much really, but to rev it to 8,000rpm you would need the billet caps and girdle, So no idea how much that is, + head work to be able to take advantage of the extra 400cc + cams + larger Valves + springs/retainers.
Just buying the rotating assembly is one thing, actually using it effectively is another.
Eg I was looking at building a 408cube stroker out of the cleveland I have, but ive decided against it because I want to use the standard cast iron heads etc, so there is no point to having an engine that big if the heads cant flow enough to take advantage.
A little different when a turbo is involved but the same basic gist still applies.
I have to agree with you on that. Also considering what other companies charge I think the price is more than reasonable and very well priced compared to the competition.
Not really In the case of the cleveland yes money is better spent elsewhere on that engine if your using the stock head.
But flow is a direct connection to the pressure drop across the valve. if you move more air under the valve the pressure drop across the valve is higher and thus flows more. thats why heads are measured in airflow at a set vaccum. if you crank up the vaccum the head flows more
Taking in to consideration the lack of a counterweighted crank shaft I dont think it would hold up as value if it were any more expensive,
Yeah thats fair enough, but if the ports simple cant flow any more air at 351cubes, than it sure as hell wont flow enough for 408, sure it will make more torque in the midrange and off idle, but past 5000rpm the power curve will nose dive like a possessed kamakazi pilot.
Really depends on the application you want it for....Just like anything else. Seeing how sweet the improvement is in the midrange, its ideal for a circuit engine. Actually its ideal for pretty well everything if you have the money. More cubes can only help, no matter how you best utilise it.
Noel I believe he is looking at making fully counterweighted items later on. Though honestly thats really of no concern to most of us unless you are aiming for sky high revs.
I 100% agree that It will be better for a circuit or street engine, I think most people buying them will be all "omg I could heaps spool 2x T51R-Spl turbos at 3000rpm" and make 5000hp.
If I were building a solid RB street/track engine I would go for one of these for sure.
But With out seeing long term high rpm use without the fancy pants girdle I will remain a non fan boy of the setup, but will wait with open eyes and ears for independent results of these kits.
Agreed 100% Mike. My comment was not deregatory in any way. Merely pointing out that if it was any more expensive then the 3.2 option from nitto with the counter weighted crank would start to look attractive. Particulalry for those wanting to rev it hard.
Something you wouldnt have to do with 3.4 litres on board.
I still want to know the rod length and pin height, My guess is the rods are around the 5.8-5.9" mark (maybe standard 25/26 length?), I dont think there is room to raise the pin heights for standard 6" rods and a 9mm stroke increase
You can pull the pin heights for an RB30 piston from 32mm (stock) back to 27mm with a custom piston height and a stock 21mm gudgen. Then you can use common 6" rods on the 95mm crank. That would be my choice to keep the rod ratio up. The other option is to use a custom piston with a less agressive pin height change (say 28mm) and then use old "school approach" with a thicker gasket (1.5mm) to accomodate a positive deck and achieve a good 1mm deck height.
I think many of you are missing the point of the stroker engine. The whole point is that you dont have to rev them, so frankly who cares if it cant rev past 8000 rpm. Look at what the R35's rev too. Displacement really does make a huge difference. And not just in when a turbo starts to respond, or hit wastegate boost. The off boost drive is much better. Throttle response is much quicker.
Also matching a head and cam configuration to the added displacement to "optimise" the package for peak power or torque isnt necessarily the ideal goal anymore. This is the conventional thinking with a stock displacement Rb25/26, to try and ring every last kw/nm out of the displacement. However suppose you can reach your power goal without having to run crazy cam and port head porting. The result will be an engine that has street manners. It will be easier to drive than an identically powered smaller engine because it will idle like stock, and produce usable torque below 1500 rpm.
    • Looks like they've been through a few versions of the kit; that is not the one I had trouble with (it had the level sender attached to baffles on the floor, the one you linked the level sender is hung from the hat). One obvious point about that kit is it has no baffles at all, not even the factory setup (although it looks like you can retain the factory setup if you want).  Not sure if that will be an issue or not, the good news is it looks like you can get the pump nice and low in the tank, but that doesn't help if the fuel is all sloshing to one side of a wide flat tank
    • One more question if you don't mind. Is the first kit you tried the same one as they currently sell as their fuel-pump-hanger kit? https://frenchysperformancegarage.com/collections/fuel-system-kits/products/fpg-bnr32-fuel-pump-hanger-kit-single-fits-stagea-c34-nissan-skyline-gt-r-r32-fpg-087?variant=42131478315186 Because according to their video the low fuel warning thing can be taken from the OEM hanger and attached to their new hanger. Just wondering whether this is the kit you weren't happy with, or whether it's a different revision. Thanks again!
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
