Hmmm... $5200 for 3.4Ls...
Or $1500 for 5.7Ls... I know which I'd prefer... :D:P
But then its not a Skyline, and I want my Skyline to be a Skyline. That is all your aircon and alternator and dash wires etc etc etc all plug in and line up. I've had engine conversion cars before and while the 'other' motors performance was better, it was a PITA when you went to o anything like turn your headlights on or believe the speedo and dash or use the aircon and even stuff like lining the gearbox and rear diff up so that you didn't chew out bearings and seals - its never that simple. I'm way over ever doing that again.
However using the 3.4 you don't have any of those issues because its the same motor by the parent company but uprated. Everything fits, the engine mounts, the clutch, gearbox, wiring, you name it, it fits. And the cost may be a bit more [but not that much more than a normal RB25/30 with forgies etc] to start with, but you will get that back and then some in reliability and not having to mod or 'bend' other parts to suit.
Of cause others will disagree, but it works for me.
  • Replies 174
Posted Images
couldn't agree with you anymore - gtr (or gtst) needs to run an rb :)
Ive been very interested in this once i saw it, but when i went on youtube, there is only a movie of the motor starting and idling.
does anyone have a link to an actual running motor?
no, not in the slightest im afraid.. :(
kinda sucks huh that this thread is a little old now. I would think that SPOOL would at least sponsor some peoples cars to test the new kit so they have an idea of the pros and cons: as a nice street motor with -5's would be my favourite even with a 7500rpm rev limiter.
Testing on tracks at constant high RPM and even some dyno queens with 1000+ hp
Many members with an rb26 are rebuilding ATM, maybe some of them can contact spool and ask to be a test/promo vehicle.
^^^I've already got insurance!!!
lol was that a troll remark about the insurance company "shannons" i was referencing to the film festival episode of southpark.
but seriously it is kinda gay nothing has been done yet, like sponsored cars or any other builds. atleast they should show a video of the car actually driving!
so buy a prototype to see if it blows up and post results here?
All for base price of 25k lol
what do u get for 25k? that is rich!
i built my rb30 complete long motor with head work, cams, rips sump, turbos etc for under 25k :)
Oh its actually pretty good. worlds first rb34 running 600hp in a clean series 2 4 door 33 with all the goodies.
http://www.spoolimports.com/used-performance-parts/car-for-sale-spool-rb34-610rwhp-r33-skyline
Edited by 045HOW
  • 3 weeks later...
  • 2 months later...
  • 3 weeks later...
Currently have our rb34 underway atm. Hopefully have it back next week ready for assembly. Wont be until early next year when its ready to run though.
I must say the quality of the kit is astounding. The crankshaft looks mint.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
