  • Replies 174
Posted Images
You reckon the ultimate rear housing would be a divided tial s/s concoction? Im sure the tial v band s/s housings must have some benefits other then easy attachment to the manifold and stainless to retain thermal energy.
We've machined up a few rd blocks with the nitto 3.2 crank. the only feed back we've heard is 1 got under 8 seconds down the quarter (methanol nos 60psi and sohc, dedicated drag car)
You have been using RD28 blocks?
Tuffer than a gtr500 block with ultra thick cylinder walls and extra webbing everywhere.
bit of dicking around to match to a twin cam head and about as heavy as a 30 block or even heavier but strong as all getup.
A mate has been thrashing the shit out of a 3.2 litre built on this block making over 700 at all 4 for 3 years or more. Bombproof!
Im pretty sure that most of that strength advantage of the RD28 block begins to dissapear once you start boring and stroking them. The only thing that would help a little is the external coolant return from the head near the back of the block on the right side.
The standard bore being 85mm does make the cylinders thicker, but in order to maintain coolant flow between the cylinders in the block, the OD of the sleeves is still around 92-93mm maximum. So 4mm cylinder wall thickness at best with a 85mm bore.
The ability to run the squirters would dissapear with larger strokes as well unless you were to slot the crankshaft like an OS giken crank, or like I did when fitting my modified RB30 crank to the RB26 block.
You have to clearence the sides of the block for the rods when the stroke is greatly increased. See the attached picture and how close the No3 rod bolts are to the side of the case, and the required case clearencing. This is an RD28 with a 90mm stroke. There will be 1mm clearence from the rod to the crankcase. The main caps are billet alloy and the main studs are offset drilled from the standard 10mm holes, to 14mm. The standard RD28 cradle wouldn't clear the 90mm crank.
Being in Australia its really hard to pass up on the RB30 block just for how easily they are obtained and adapted to an RB26 head. In my opinion, there are other opportinities such as sleeving that people should really consider a lot more befoer heading down the RD28 conversion path.
Ive seen that picture somewhere before. Very tough setup.
Possibly on the GTR UK forum. Its from an 8 second R32 GTR in Urkaine. He ran an 8.16 with this setup. A rod went through the side of the block though, and now a new engine is being built to replace it.
is the owner rebuilding another rd28 or making a switch to the rb30?
He's keeping the RD28 block and replicating what he had with some improvements. Availibility of the block is the main factor though. RD28 blocks are easier to source than RB30 are for him.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
