Ok .. Well, I've done a bit of research so far, and this is what I've found ..
The guys @ The Pits seem to think as long as the light is white (not purple tinged/yellow/blue) it's ok.
The Technical Department @ Welshpool have said its only ok as long as the kit has ADR approval.
Speaking with Philips Lighting in Sydney (who are about a month away from releasing a kit in Australia) have said that the ADR basically states:
Retro-fitting a halogen headlight with xenon globes requires that the headlights are self-levelling and self-cleaning.
I'm trying to hunt down the ADR to confirm this, but whats interesting is that all the latest Euro cars with xenon don't seem to match this criteria. It appears that the BMWs *DO* self-level, but they aren't self-cleaning.
So, it doesn't appear that they will be legal, but the chances of the pits picking you up on it are slim, and even if they do, the original halogen connections are a sinch to reconnect to put the old globes back in.
  • Replies 50
  • 1 month later...
HIDs are cooler than Halogens.
I have 2 cars with Xenons and both of them have different setup.
On 1 car the which is an older system, the high beam is separated from the main Xenon bulb. On the other (most of them going to Bi-Xenons) meaning they both use low and high beam on the same bulb.
All cars that came with xenon as standard (for my cars anyway) DO have self cleaning system and self leveling.
I will be getting another vehicle soon and will let you all know on the latest xenon setup which follows the direction of the car.
Oh, once on a xenon, I will never go back to Halogens.
Munich
PS: You can PM me to find out more about xenons :)
r34
You know you shit listen to this person.
i has a kit in low beams and a kit in the high beams. the switch has bean modified so that the lows stay on when the high beams fire up. i have been pulled over twice and the cop did the white paper test and said have a good night with no problems.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
