Ok .. Well, I've done a bit of research so far, and this is what I've found ..
The guys @ The Pits seem to think as long as the light is white (not purple tinged/yellow/blue) it's ok.
The Technical Department @ Welshpool have said its only ok as long as the kit has ADR approval.
Speaking with Philips Lighting in Sydney (who are about a month away from releasing a kit in Australia) have said that the ADR basically states:
Retro-fitting a halogen headlight with xenon globes requires that the headlights are self-levelling and self-cleaning.
I'm trying to hunt down the ADR to confirm this, but whats interesting is that all the latest Euro cars with xenon don't seem to match this criteria. It appears that the BMWs *DO* self-level, but they aren't self-cleaning.
So, it doesn't appear that they will be legal, but the chances of the pits picking you up on it are slim, and even if they do, the original halogen connections are a sinch to reconnect to put the old globes back in.
  • Replies 50
  • 1 month later...
HIDs are cooler than Halogens.
I have 2 cars with Xenons and both of them have different setup.
On 1 car the which is an older system, the high beam is separated from the main Xenon bulb. On the other (most of them going to Bi-Xenons) meaning they both use low and high beam on the same bulb.
All cars that came with xenon as standard (for my cars anyway) DO have self cleaning system and self leveling.
I will be getting another vehicle soon and will let you all know on the latest xenon setup which follows the direction of the car.
Oh, once on a xenon, I will never go back to Halogens.
Munich
PS: You can PM me to find out more about xenons :)
r34
You know you shit listen to this person.
i has a kit in low beams and a kit in the high beams. the switch has bean modified so that the lows stay on when the high beams fire up. i have been pulled over twice and the cop did the white paper test and said have a good night with no problems.
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
