  • Replies 50
Having had an R34 with Xeon lights all I can say is once you've experienced it everything else looks pretty weak.
There seems to be some misconception on this site about these lights.
Firstly they are only permitted for low beam as the startup time delay makes them useless for daylight flashing use.
Your Highbeams are a separate globe and from memory the '33 turns it's lowbeam off on highbeam. If this is so just rewire the lowbeams to stay on.
No way will wiring melt, these globes are 35W not 55W halogen and even accounting for ballast losses the total current draw will be less than halogen.
On startup they may draw more power until up to operating temp but that's about a second only.
The pits can pick you for them if they really want too but it seems strange that BMW's Audi's and Lexus run them stock.
If hassled just revert to halogen temporarily.
They are a great safety benefit so any reasonable pit inspector would let them pass.
Cheers
I just recently installed HID in my R33. Highbeams work fine.
Have been past many cops and haven't been picked up yet. The only attention I get is from other cars and pedestrians due to superiority of light compared to the halogen. Make the car look really cool at night..
It would be interesting to know the legalities as they are pretty damn bright!
nah i was saying that from the lil animation on the site, it was saying how it doesn't allow the use of highbeam, or some utter shit like that, i now truly believe the meaning of don't always believe what you read :bonk:
adrian :D
OH MY GOD
For those that have NOT seen xenons in an R33, see if you can hook up with Chris (CC).
Just went for a spin with him following me and then he took me for a drive, and OMFG!! It is totally amazing.
My girlfriend is going to totally hate me now, because I need xenons. It's that simple.
Jason - didn't evolution R muck about a bit before it got it's act together to provide the dials for the last group buy? or am I wrong and should be told to shut up? :rolleyes:
it was car quest that did the mucking about cam, evo r seem to have caught the same bug that raymond has...it seems.
how many are outstanding now.
Jason....xenons....will they help you keep up with all the other skylines on the cruise. or are you intending to just fall behind and then fry them with light power
i guess if you install the HID kit, and then angle your lights a little more down than usual, especially in a series II with the different headlights then you could prolly get away with it.
the brightness that is
tilting the lights down does very little as HID throws light out in all directions..
when I tried to get mine levelled, it came up with a blank reading..
i think a special headlight assembly is required, but not 100% sure
I've just spoken with the Technical Department for Vehicle Examinations in Welshpool and have been advised that:
1. Changing Halogen to Xenon is acceptable, only if the Xenon kit complies with ADR (Australian Design Regulations)
2. They will not supply that in writing, because if the product complies WITH ADR, there is no need for you have it in writing.
It was recommended that I contact places like Hella etc, who make Xenon kits and to discuss with them the situation, and because they are fully aware of the ADRs, they should be able to provide me with any further information.
Later today I will contact Hella and possible Bosch, Panasonic and Phillips (all of whom I have seen have some part to play in the creation of Xenon kits, be it the Ballast or the Ignitor systems) and see what I can find out.
Hicks, not all of us have disposable income to go out and purchase things we want/need at a drop of a hat. Xenon lights up the road so much better than Halogen lights, and as I enjoy night cruising, I feel that is it something that *I* need.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
