hi all as all you can see im parting out my r32 gtr that ive had for 5 years now, im wanting to put back to close to standard and sell the car as it is with no mods to it as i have to go through EPA so i cant really afford to put all parts back on, the parts are all quality parts have never took a short cut on this car in the last 5 years, car is still running fine, it makes over 300awkw on 18psi safely, parts i have are:
HKS gt25/30 turbos with hks actuators
tomei dump pipes, the hand welded ones that apparentely are better and are a 2 3/4"
greddy 100mm trust intercooler with the greddy aluminium pipes, greddy hoses and all the heavy duty clamps
apexi power fc (doesnt come with handcontroller)
nismo 555cc injectors
z32 afms, tomei plugs with the custom piping for the z32 afms fit the r32 gtr, come with almost new apexi pods
blitz DSBC
nismo fuel regulator
sard 280 fuel pump
impul 3" stainless front pipes
n1 head lights
blitz BOV's
hks 3.5" stainless cat back exhaust system
like brand new recentely installed Tomei 260deg 9.15mm lift cams
greddy cam gears
clear cam gear cover
like new cusco zero 2 coilovers
ARC aluminium radiator
greddy aluminium raidator pipe
carbon fibre bonnet, not sure but looks like a D-speed payed $830 from a sau member a little while ago
morosso oil catch can
parts are still on the car but i can take a few pics or if yous want to come and inspect the car as im in melbourne located in the northern suburbs,sms or contact anthony on 0412862091 anytime or PM me but im not always on here
the car will also be for sale or i will sell as it is whith the parts still on it, its in abbroad minded personely sparkling condition probably one of the best r32 gtr's out there but car has really made me go broke and cant afford to take parts off and put back on, i havnt received the letter from EPA yet but they wrecken i will get it in the mail,
thanks for your time guys cheers
Interested, not paying more than 790 coz thats the new price at justjap.
Closed.
No prices listed, not to mention I am quite sure you are not the owner of these parts and are advertising them on behalf of a banned user.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
