Hey guys
ok so gonna go ahead with the next bunch of mods... aiming for 350 - 375rwkw on E85
car is R33 GTR VSPEC
current mods are (producing 270rwkw)
- PFC
- 3" cat back
- Garrett -9s
- shitty compliance cat
- stock everything else
I need help with the following. Rather that just stating the type of part i need, it would be really helpful if people can suggest a brand and part.
I need:
- intercooler core (how thick should I go without creating any unnecessary lag)
- Injectors - 1000cc?? which brand??
- Fuel pump - I dont think an internal bosch 044 will be enough flow... will one external do the job??
- clutch - im thinking a jim berry item... do i really need a twin plate... (i am planning to take it to the strip every now n then)
- cam gears - which brand???
- boost controller - do i really need one?? or can my tuner mess around with the actuators to get the desired pressure
- exhaust system - 3.5" item
- z32 AFM - easy one
keep in mind that my budget excluding the exhaust is 4-5k... if its necessary then will fork out the extra $$ for a bigger exhaust
planning to tune it on 98 for now, but will retune for e85 when caltex do their thing
please advice
cheers
Umair
i didnt think the -9s would make that power???
stock cooler should be ok.
Jim berry Full monty clutch should be able to handle it and an occassional drag run
cam gears any brand, they all do the same thing, need to be tuned anyway.
use a decent brand EBC, profec b is affordable and very easy to setup
-9s on E85 should crack 350
i'm pretty sure i need a cooler... stock ones are good for 300ish kw from memory
yeh had profec b in old car so will prob grab one of those again (just wanted to check if they were actually needed)
made the mistake of putting a 'cheap' clutch in the old car which just fried spirited driving so I want to make sure that doesnt happen again.
thanks bud
keep em coming :)
Hey Im not sure what the -9s can flow but ive got 380rwkw on e85 with the following setup
PFC
HKS 2530s
R34 GTR intercooler (standard R32 cooler made 360rwkw)
850cc delphi injectors
2 intank walbro pumps (one 044 not enough)
no cam gears !
ive got nismo twin plate alot easier to drive with compared to single plate but will do the job fine
GREDDY PROFEC B boost controller ( u need good boost control !)
3" exhaust with ebay dumps and 2.5" downpipes
RB20/25 afms
Edited by GMASTR
interesting... 380rwkw on 3" exhaust... guess i dont really need to upgrade that
thanks for yr input man... how are your injectors holding up?? getting close to max duty cycle??
I'm going to upgrade my cooler just to be on the safe side
Yes, you do need larger. The gains to be had a quite substantial.
The E85 in his instance is somewhat masking the issue.
Cooler will also be fine mate, plenty of people here 380rwkw on the stock cooler. Some even more...
PFC
HKS 2530s
no cam gears !
RB20/25 afms
2530's will do 380-400rwkw on PULP. E85 + 2530 = 420-440rwkw territory.
But then you don't have a built motor and a filthy restrictive exhaust...
No woryz man, the exhaust has a 3" cat and two straight through mufflers and is street legal ! The only thind i needed to change were the front injector seals once, they became hard from e85 and started leaking under boost otherwise all good, my injectors are at approx 70% duty cycle, Its a good idea to change ur cooler, ive kept mine stock bcoz i wanted to achieve the most power safely using a standard motor and factory surrounding parts :(
Make my 3.5" exhaust on the HR31 is 90-91dB, I can assure you it's quieter than most 3" systems i hear around here.
Whenever i go on a cruise I'm totally stealth thats how quiet it is.
4" isn't much worse either provided you get GOOD mufflers and a big flowing CAT.
Owning a GTR isnt cheap, nor is chating 350-370rwkw... If you need a 3.5" or 4" exhaust, then pay for it :)
3.5" should do you for your setup either way.
  • 4 months later...
Put ID1000's in it, mid $600's for a set.
Get cam gears definately, they are cheap !
I got a set of GATES RACING Cam Gears and timing belt in a package of the GCG AUS website for like $150, do the timing belt when you put em on !
Don't skimp on exhaust, it gets exponentially more important the more power you run.
Those turbos are too small, sure it could probably be done but do you really want to stress the your engine that hard ?
I hit 370rwkw on e85 with the following setup
2860-5's
2 x walbro intank fuel pumps
1000cc injectors
Nistune ECU
NISMO AFM's
STD Airbox
STD R34 GTR intercooler
3in exhaust
Turbosmart E-Boost street
STD cams & cam gears
I've got a Jim Berry Clutch in mine and its great!!
i dont know how your turbo's would go compared with mine?
but you dont need to change intercooler for 350rwkw, and a 3in will do 350 easily
i am finding at the moment that the STD cams, STD intercooler are holding me back from more power and maybe the exhaust too.
i am pretty happy with the setup now.
the only difference in running e85 compared with PULP is the need for a bigger fuel system.
i had 350rwkw on PULP before going to e85 and the only change i made was going from
660cc injectors to 1000cc injectors
1 x walbro fuel pump to 2 x walbro fuel pumps
STD fuel lines & rail to a second fuel line from the pump to the rail and mod the rail to suit
retune with more boost and enjoy the added midrange.
you will probably notice the biggest difference in midrange going from PULP to e85
  • 3 weeks later...
Yeh mine made 270 with stock dumps, front pipes and a compliance cat... so the consensus seems to b 2 pumps and 1000cc injecters as a minimum... the car now has bigger front pipes, hi flow cat and 3.5" catback so we'll see what happens
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
