the rear camber on my r32 gtr is scrubbing out the inner edge of my tyres, so thought i would get it sorted.
the car has tein coilovers and is fairly low. Are these camber arms the best way to fix it??
the car only gets street use, so i dont want it to stiff, do these do anything to the ride quality?
cheers
http://cgi.ebay.com.au/POWER-SPIRIT-REAR-U...=item1e5e1fe271
https://www.sau.com.au/forums/topic/345034-r32-gtr-rear-camber/
hey,
there are 2 ways you can fix this,
depending on the amount of coins you wish to spend.
cheap easy and nasty first would be to take an angle grinder to the little lip on the inside of your car and roll it out with a gaurd flare tool or a hammer.
the preferred option would be to buy rear camber arms (this is what i have done with my 33 gts as i am running gtr offset rims) this will cost you around $600 i suggest ICS performance online. But you will be burning through tyres as a result from only the inside of your tyre will be providing traction in a straight line.
mate,
i think you have misunderstood me, my car is already burning through tyres because of bad negative camber.
that is the problem i am trying to fix.
just want to know if the camber arms are the best way of fixing it.
my tyres dont touch the guards! even with 18x10 rims and 265 tyres there is plenty of room.
hey,
  • 5 months later...
mate,
Yes, Rear upper camber arms is exactly what you need. You will need to get a wheel alignment afterwards. There is a range of brands to pick from. JJR, ISC, Cusco, KKR... I dont recommend non brand ebay items. I run JJR in my car.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
