Recently, i found that my clutch goes from soft and comfy to suddenly very stiff, it is a very shocking transition, but after pumping a few times, it goes back to soft again.
And occasionally, (more like daily now), when the weather gets pretty hot, i sometimes hear a squeal when depressing the clutch pedal, seems like its coming from the pedal, but then sometimes it seems like its coming from elsewhere, like the squeal only starts when the pedal is fully depressed. It sounds like opening a door with unoiled hinges (i'm hoping that's what it is, unoil pivot ball).
So, i think i've narrowed down to these 3 probable issues.
1. Air bubbles in the system
2. Master Cylinder is kaput (well it was $30)
3. pivot ball needs oiling, or destroyed (gearbox out) =(
How now brown cow? Does somebody want to come drive the car for a bit and tell me the issue? =D
It didn't start till the day of my first paper, on the way to my exams, the clutch suddenly became hard, and then lasted that way till i arrived and parked, no leaking fluid, but the reservoir was low. When i finished the paper, clutch was fine again.
Clutch is an OS giken twin plate,
everything else is stock.
I previously had no pressure in my clutch pedal and had to drive around by turning off the engine, putting it into gear1, then starting the engine to move off, rev matching to change gears. The issue was fixed by changing the vac booster, so if anyone is facing the same prob, try it.
There you go, hope i can have an idea what the issue is with the silly car, and then come back and stamp out all those gremlins.
https://www.sau.com.au/forums/topic/345062-clutch-issue/
My first guess would be leak somewhere in the clutch booster system (its looks and works like a brake booster, but smaller)
https://www.sau.com.au/forums/topic/345062-clutch-issue/#findComment-5560516
hmm, where is that booster thingy you talk about?
are you talking about the vac booster? next to the master cylinder? that thing is huge though...
https://www.sau.com.au/forums/topic/345062-clutch-issue/#findComment-5560783
Its a lot smaller than the brake booster, lower down and closer to the transmission tunnel - IIRC its probably about 10cms in diameter and yeah it will have the clutch cylinder attached in much the same way as the brake master is attached to the brake booster. Check the vacuum pipe going to it for leaks.
If what i've said doesnt match up with what you see let me know and i'll go and have another look - the above is all from memory, and i have a crap memory...
https://www.sau.com.au/forums/topic/345062-clutch-issue/#findComment-5561462
oh well, car is driveable, will visit the mechanic when i'm back in feb then..
too much headache to self diagnose...
https://www.sau.com.au/forums/topic/345062-clutch-issue/#findComment-5561582
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
