I'm rebuilding my head using Supertech valves, hydraulic spring kit, seals, valve guides. I'm also rebuilding the bottom end with supertech pistons and eagle rods N1 oil and water pumps.
I'm running Nistune with an Rb20 ECU, so I don't have VCT, I want to buy uprated cams, should I buy the Tomei pon cams or the Greddy easy cams for the VCT or use a different profile cams and remove the VCT?
If which would be the best and reliable set up for a 500 to 600 BHP car, daily driver a lot of autobahn and some track.
https://www.sau.com.au/forums/topic/345065-which-cams/
You have to buy a seperate controller or alternatively swap your ecu for a Z32 one I believe and stick your nistune chip in that. There are a few tricks to it which i don't know (try searching). Better still would be a Link ecu which will also control the VCT :
http://www.linkecu.com/dealers/germandealers
A cam gear on the exhaust cam is not an alternative to VCT - ideally you would do both.
https://www.sau.com.au/forums/topic/345065-which-cams/#findComment-5560098
advance up the intake cam with cam gears if not running vct it will help alot.
I got good results with 256 degrre 8.5mm lift, i think i ended up around 8 degrees advanced on the intake..
here is the thread http://www.skylinesaustralia.com/forums/Rb...ft-t308743.html
https://www.sau.com.au/forums/topic/345065-which-cams/#findComment-5560114
using this diagram, I beleive I have to connect it to pin #113
http://www.skylinesaustralia.com/forums/ip...ECU_Pinouts.jpg
Also, which Tomei cams would be better? Is it only one type for the RB25 with VCT and Hydraulic lifters?
Or what about the Greddy easy cams?
https://www.sau.com.au/forums/topic/345065-which-cams/#findComment-5560676
Pon cam for vct and hydraulic lifters. Two types for series one and two.
Edited by WHITE gtt
https://www.sau.com.au/forums/topic/345065-which-cams/#findComment-5560803
Trent did you try variations on total increase in overlap? Eg IN+4, EX-4? Still gives you 8 degrees but I'm interested to know how it affects the torque curve.
Using a Tighe grind on my 30/25 and it seems that there is a point where the mid range is noticeably fatter but torque at the top end falls away and you end up short shifting a bit. Note this is a bit of subjective feel, trying a few settings on the road before slipping it onto the dyno.
https://www.sau.com.au/forums/topic/345065-which-cams/#findComment-5560861
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
