Hi guys.
Recently blew the bulb in the right-hand side headlight. I've been doing a bit of a search and people have been saying that you have to get 'D2R' headlight bulbs or something?
Can I not just buy the bulbs that they sell down at the local Supercheap or Repco?
Also getting the bulbs in.. Seems quite tricky since I can't really fit my fingers anywhere near the back of the bulb holder. What's the easiest way to replace the bulbs?
Cheers.
https://www.sau.com.au/forums/topic/345092-replacing-headlight-bulbs-r34/
Remove you battery and you should have plenty of room,
did mine a couple of weeks back,
just unscrew the dust cap and sqeeze the spring clip change it and put everything back.
are you using the factory xenon plugs or normal halogen globes?
try ebay,
i bought a HID kit for mine, both headlights for about $60, so a globe should be next to nothing,
just make sure you get the right globe.
HID globes from auto shops anre upwards from $200 depending on what type of globe
How the heck is there such a massive difference in prices for these? ZXY you said you paid $40, whilst R34Mobster paid $275 for a pair and I paid $308 for ONE! I'll wait till I get it from the shop next monday and will update you guys.
did xspeed sell it to you? If so try and take it back cause they've taken advantage of you. As others have said hop on eBay or find a trader on here you can get 2 for less than 100
Edited by gersfan
you need to do research before paying that type of money. $308 is alot of money for a bulb. If you went to dealers, i doubt it would even have been that much.
  • 2 years later...
pull out one of your current bulbs and have a look. on it you should see some code/model number, and some of that should contain "D2R" if you're lucky. If so, then yeah it's the right bulb you linked on ebay. if you're not sure then chuck up a pic for us here and we can verify for you. also, i should mention that if you want to go the Japanese spec, search up garax HID on ebay, they are great bulbs.
Ahhh, ok, well just got the car few days ago, so will defs take a pic and put it here so can verify what bulb, just gotta see how I take it out haha xD
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
