Hi guys.
Recently blew the bulb in the right-hand side headlight. I've been doing a bit of a search and people have been saying that you have to get 'D2R' headlight bulbs or something?
Can I not just buy the bulbs that they sell down at the local Supercheap or Repco?
Also getting the bulbs in.. Seems quite tricky since I can't really fit my fingers anywhere near the back of the bulb holder. What's the easiest way to replace the bulbs?
Cheers.
https://www.sau.com.au/forums/topic/345092-replacing-headlight-bulbs-r34/
Remove you battery and you should have plenty of room,
did mine a couple of weeks back,
just unscrew the dust cap and sqeeze the spring clip change it and put everything back.
are you using the factory xenon plugs or normal halogen globes?
try ebay,
i bought a HID kit for mine, both headlights for about $60, so a globe should be next to nothing,
just make sure you get the right globe.
HID globes from auto shops anre upwards from $200 depending on what type of globe
How the heck is there such a massive difference in prices for these? ZXY you said you paid $40, whilst R34Mobster paid $275 for a pair and I paid $308 for ONE! I'll wait till I get it from the shop next monday and will update you guys.
did xspeed sell it to you? If so try and take it back cause they've taken advantage of you. As others have said hop on eBay or find a trader on here you can get 2 for less than 100
Edited by gersfan
you need to do research before paying that type of money. $308 is alot of money for a bulb. If you went to dealers, i doubt it would even have been that much.
  • 2 years later...
pull out one of your current bulbs and have a look. on it you should see some code/model number, and some of that should contain "D2R" if you're lucky. If so, then yeah it's the right bulb you linked on ebay. if you're not sure then chuck up a pic for us here and we can verify for you. also, i should mention that if you want to go the Japanese spec, search up garax HID on ebay, they are great bulbs.
Ahhh, ok, well just got the car few days ago, so will defs take a pic and put it here so can verify what bulb, just gotta see how I take it out haha xD
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
