interested to see how u go with that turbo i have been thinking about using the same one except low mounted on the stock manifold with a spacer/wastegate adaptor. but im thinking its gonna be restricted greatly by the manifold so i might just use their td06L2 with the 10cm rear.....
Exactly what my plan was until the turbo arrived... The front compressor housing is big (like a Garrett 0.7) and it was going to need like a 30mm spacer!
In the end I figured getting a spacer, another gasket, the exhaust housing welded etc was all going to be a headf**k (and decent cost) so I just ended up going a 6boost. Plus as you said the standard manifold was probably going to be a restriction at the power I'm trying to make.
The TD06L2 10cm also seems like a good option, I think the only difference being it is water cooled as well. Plus I have read that the 20g front wheel really runs out of puff at about 270rwkw
PS. Shouldn't have to wait long, car is going to be on the dyno this week (fingers crossed maybe even tonight)
T67-25g 10cm Photos
Tial 44mm Gate
6boost Manifold
Looks pretty good :)
Edited by SimonR32
Turbo looks good, Simon & Battery, the T67-25G and the TD06-20gL2 share the same turbine wheel and housing, the difference is the T67 uses a TD07S comp wheel and housing, which is also the same as the TD06-25G
the adaptor i have is similar to this...
but yeh that t67 is pretty big :) ill be putting it into a 33 which i think will give me a little more room?
i'd love a 6 boost but im not really interested in paying the $1300 to get one!!
there seem to be a few guys pushing 260-270kw with the td06L2 8cm rear on sr20/rb20, so i think it may be possible to get to 280kw with the 10cm rear...
Keep looking around for a 2nd hand 6-boosy, I sold mine which was a twin scroll T4 for $500.
yeh i could stomach $500..
i think ill wait for simons result before i decide on anything, should be interesting...
what are the lines and fittings included in the kit like?
Oil feed is good (you need a fitting to go into the block), oil drain was a tad short so we are replacing with a braided line (better to be safe with heat + oil = fire)
I'm crossing fingers for results tonight... All we have to do is the oil drain, dump pipe and gate screamer pipe!
SO, sick of toasting RB25 boxes behind a 20 so you throw a more powerful RB25 engine in front of the same sort of gearbox? :) Any excuse to lose the RB20 ay? :)
Interesting to see how it goes...you guys are just rough bastards. My car will hit 200,000kms this weekend at Winton and its still the original gearbox !
Don't you like my reasoning haha
Roy I love my RB20's and always will, but times are changing and I just couldn't see a way to keep up with the Jones without going more capacity :)
Got some results via text message, made another 100hp will post graphs soon
Actually ended up going 517rwhp (386rwkw) without correction...
So that is a 127hp more than the RB20, plus it's 700rpm quicker to come on boost and nearly doubles torque between 3000rpm-5000rpm
Does nothing but burnouts in pretty much all gears
I know what turbo my 1jz is going to get now!!@!@!@!@1
What fuel? Throw some decent suspension and tyres at it now.
I've got all adjustable links but my rear shocks are not the best... I have a pair of RE55's at home but don't want to lap them on the street so the plan is to get some KU36 and see how they grip.
I'll post the graph up pretty soon but it makes 15psi at 4000rpm which is a bit later than STATUS results but it may be because of the fuel (which seems to make turbos laggier on most cars) or because the turbo was literary brand new when it drove on the dyno with no run in.
Still massively impressed with the results, the car feels about on par for pace as my old GTR which makes for a scary RWD
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
