My suggestion for the 24mm front bar was just to complement the GTR rear..but i looked it up and GTR rear bar is 25mm, (i thought it was 22mm), so would be better go the 27mm front.
"Rear-wheel drives that oversteer, or pick up an inside rear wheel and spin it, often benefit from a upsized front sway bar"
Maybe just start off with a thicker front first and see how it handles..
GTR OE is hollow vs Whiteline solid so slightly different. You wont find Whiteline part numbers for the bars that Russel runs. Like I said they are my old custom ones and not off the shelf catalogue items.
When you factor in the money for deliveyr etc and their generally cheap price. Just buy a set, that way you have a proven swaybar receipt.
yeah true..
do you know why there is no thicker front bar option Roy...general rule of thumb has always led me to believe the front should be a little thicker is all...or is it just the 33 needs bigger bars cause its a boat
Though i guess there is a 22mm rear option too...
Ok I think I have come up with a plan... Let me know what you think :)
Set up the subframe as per below, yellow = whiteline bush and red = kazama ally lock bushes
Buy some Whiteline 24mm adjustable sway bars (front and rear) and run them on the softer setting
Run 255/40's on the back and wind the coilovers to the softest damper setting
id be trying this first ... and its a cheap option first and only making sutle changes so you can actually get a real feel for what is going on and then fine tune from there
+ front sway is obviosuly adjustable so can play around a little to suit if you keeping the gtr rear sway
if you want to go adj 27mm whitelines, they were custom made when i bought them only extra few $$ got them done through WA Suspension in a few days
If you ring whiteline you should find that you can get them to make you a bar of any type or thickness you want. Of course there is a wait time but they are just like King springs in that they do custom orders all the time. We had to wait 2-3 weeks for our custom spring order and recently had some not-on-the-shelf whiteline bars produced for us as well. Might be worth looking in to
Cheers for the heads up... Unfortunately time is not my friend as the track battle is next weekend. I'm going to start with a 24mm adjustable front and keep the GTR rear for now :thumbsup:
With your traction issues simon you springs are too stiff, 8 and 6 is for drifting, you could almost half that and get better performance.
Use swaybars to reduce body rolls, not springs. Also the valving in most coilovers is rubbish.
Edited by Rolls
Really? I am running the same spring rates (albeit with different shocks) and my car is fine. In fact I think it could be lacking a little spring all round and considering going up in spring rates now that I dont have my larger swaybars. Tossing and turning over that decision, I either need my old swaybars back or more spring.
I dont think 8 & 6 on shocks that are of reasonable quality and condition are a problem on a GTSt running good quality semi slicks? I used to run what you propose spring rate wise on my old Bilsteins and on semis it scraped its door handles on the ground in the bends.
yeah i would have thought 8/6 was a good compromise with mid strenght sways the front a bit heavier than the rear would be close to perfect..the rest can be sorted through adjustment of dampening and alignment settings
Yeah 8/6 seems to be the general consensus of what is decent :)
Whiteline front and GTR rear it is... Now I have the issue that tyres are not available, so I might just have to run the tuner class with the 235 RE55s
Will be a good comparison to see if I have gone forwards or backwards in set up
Ok so I ended up getting most the stuff done that I wanted before the weekend (just)...
Installed the Whiteline subframe bush to set diff angle to maximum traction
Turned all the dampers back to soft on the Greddy coils
Installed a Whiteline 24mm adjustable front sway bar and set to hard
Got some New AVS model 5's 17x8+38 all round and mounted my 235 RE55S
and left the wheel alignment the same :whistling:
Car was a LOT better to drive, didn't feel like getting on the gas was going end up with me being killed as the result of massive over steer. Corner entry was also better, the back wasn't kicking out as much. So much more confident in driving the car at fast speeds, even traction in the straight line seemed to be improved :thumbsup:
So we only did the long track which was new to me over the weekend and I managed to do a 66.7sec while still getting used to braking points and not pushing overly hard. They say there is about 10sec difference between short and long so I have defiantly gained some time and didn't have to push anywhere as near as hard to get there so happy days :cheers:
For next time at the track I think I'll be adding some R33 LCA's to get camber at the front up to -3.5deg and have another crack at short track. If I can get down to the 54's I would be stoked :)
Yeh, so many S13/R32s etc all complain about not being able to get 180-200rwkws to the ground and these days I automatically assume its because they run "fully-sik" all sub frame bushes.
or using $20 chinese tyres :P
If you are running true semi slick and only driving it on a race track I agree, anything else and imo the slightest bump and you'll be getting wheel spin.
What dampeners are you running? The issue with most 8/6 rates is they come in a coilover kit with crappy shocks.
Edited by Rolls
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
