dunno if its mentioned, what oil pump u running?
also what fuel?
and what size is the garrett equivalent?
Motor and oil pump are stock...
Fuel is a mix of 50% Sucrogen E85 and 50% BP98
Garrett 3076R is a tad smaller on both sides but the closest you will get :)
"CURRENT R32 Gts-t 410rwkw CLICK HERE FOR THE BUILD THREAD! "
So wheres the 410rwkw update? LOL
Few tweaks in tune/boost and turning on SAE correction it made
Same tune on a dyno dynamics in shootout mode 359rwkw
Shows the difference different dynos can read :)
Hopefully down the black strip dyno soon to show some decent mph
Keen to see it run down the quater Simon, how often does she get driven & where do you source your e85 through?
Usually don't drive it heaps because I have a work vehicle, maybe a few times a week! Mates R34 with similar mods but 50hp less ran 11.5 @ 128mph about a month ago so fingers crossed it goes ok :)
Got the E85 from RPW in 205L barrel
Im guessing it was that white r34 at whoop ass a few weeks back. What boost are you running now with your power increase? 410kw is some awsome power out of a stock 25 :)
Yeah that's the one :)
Boost is around 1.8bar dropping down to 1.5bar... I think the turbo is giving all it can give!
im so considering getting a smaller kando turbo for my rb20!
haha
but i'm also kind of scared ;P
Go a TD06SL2 20g on the RB20... It will fly!
what size is the exhaust off the turbo?? 3" or 2.5" im doing a setup with one of these turbos, wondering is my 2.5" dump with a few mods will be anygood, or should i just get a new one made
It's a 3" v-band off the back of the turbo so you want it at least 3"
cheers, looks like a new dump it is then, question is now, do i get it welded in 1 piece with the front pipe, or make it seperate.. my front pipe is 2 1/2" flange but 3" it has a reducer.. probably better to chop is off and weld 3" to 3" :D bit of a waste, i just bought a new flange to stuit it. oh well, thats what happens when u change ur setup :D
f**k it! i'm gonna order a TD06 :D!!
should be bolt straight on if it has a t25 flange!! :)
agreed i run a td06 and my little rb20 hammers
also great build thread car looks great not to overdone and very straight.
Edited by Yts
:O!?
few questions :P
was it very simple to setup?
was there any problems setting everything up
what model did you order?
and was there any after costs?
:O!?
few questions :P
sent you a pm, back to the awsome build thread, how bout posting some more footage of it?? or even on the dyno?? and have u got any more future plans
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
