Great build man :thumbsup: has inspired me to drop a 25 into my 32 gtst to spice things up again. Are there any clearence issues with droping the 25 in as mine will be mainly used for street i would like to keep the a/c ect and can my power fc currently running a rb20det also run a rb25det or will i have to upgrade/swap the computer?? sorry for the newbie questions
The 25 is 18mm taller, other than that it's the same dimentions. If you get a s1 25, you can use the rb20 loom and ecu with a nistune and vct controller or z32 ecu (internal vct controll).
It's the best thing I ever did with my gts-t..
Yeah they fit piece of piss...
You could use the power fc with a vct controller but I would recommend a Z32 ecu with RB25 loom and nistune as per XRATED above :)
awsome build buddy. did you wire the 25 in yourself or pay some one if so how much.
No wiring needed because I'm running a RB20 ecu, loom and sensors... Just needed to buy a RPM switch to turn the VCT on/off (I used a Greddy MSS) and have that wired up which was pretty easy
Finally got around to doing the brakes upgrade.
Went from standard stuff to...
R34 Front Calipers to suit 310mm disk
RDA slotted rotors all around
Hels bradied brake lines
QFM A1RM pads all round
Looks a lot better now, fills out the wheels more and should hold up well for the time attack on Tuesday night.
Finally got down the track last night and managed a 58.0 at Barbagallo short track which isn't too shabby, also picked up the trophy for fastest RWD on the night :) Only revving it to 7000rpm and using 1.4bar on the track and everything held up mint with no issues at all!
Managed to lock up the front left and flat spot the tyre being way too eager on the brakes into the first corner early in the night and was going 0.5sec faster on every session so there is a lot more time to take out of that in the future. I used some Dunlop D02G 225/45/17 that were second hand and on the tread wear limit, I'll have another go on them next time and rotate the flat spot to the rear before I bring out some 235 RE55S and see what I can do.
I think I should be able to run a 56 with the Dunlops and try for a 55 on the Bridgestones in the future :)
i did not watch any of the vids or understand most of the words used but damn. alot of work and alot of love went into this car. almost makes me wish i had got an r32 insted of my 4 door r34 :cheers:
nice work
Edited by thejedilestat
Some pics from the time attack night :)
Just purchased myself front lower castor rod brace and going to get some front fender braces soon as well just to stiffen the old girl up a little more before I head back on track.
Also have a Hel's oil cooler kit with thermostat on its way to keep the oil temps in check when thrashing,
Edited by SimonR32
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
