Had a time looking for the correct pads to fit my car..... spent a decent while at repco, supercheap, brakes plus and few other stores.
But finally realised that,
Fronts
DB8382
Rears
DB1144
Hope that Helps.
Cheers
https://www.sau.com.au/forums/topic/345138-r34-25gt-sedan-brake-pad-model/
  • 2 years later...
Fronts
DB8382
Rears
DB1144
Hope that Helps.
Cheers
* CORRECTION *
-- Fronts are by a manufacturer called "Maxi Stop" Part Number : M-D-B 8382
-- Rears are by a manufacturer called "Maxi Stop" Part Number : M-D-B 1144
I cant seem to find the fronts by Bendix anyone got any idea?
You might be right, although the first time I tried putting those in (couple of years ago).They didnt seem to fit easy.
I went to a clutch and brake place in dandenong and the dude measured by pads and gave me the Maxistop MDB 8382.
Not the greatest set of pads. So i'm looking for the bendix replacement. The images below show the measurement problem.
I also looked up for the OEM part number on Nissan Fast.. Then did a google search for it and found this on a website called autopartoo.com which gives the dimensions of the pads.
But I'll try again with the bendix pad today and see how I go.. I've got a soft pedal so will be bleeding the system.
Edited by R34-98-4D
