If i purchased a stock auto 94 r33 gtst with about 100,000km on da dial and went up against a manual 93 honda integra vtir with a full 3'' exhaust system, air filter, extractors with 180,000km on da dial. i should win right coz i have turbo. dis might sound like a stupid questions but im still new to cars comin from bikes. how would i fare up. would i still rip him or, just, or lose. Newbie needing help.
https://www.sau.com.au/forums/topic/34515-newbie-question/
well u "should" but i wouldnt' think an auto skyline is that great if i were u ... i got one myself ... the loss in power with the auto is too much i think ... but what can u do?? anyways hit the brakes and press the acc and rev it to about 3k just before u let go so u launch at 3k ... anymore and it might be a bit dangerous for the auto trans ... anyways u should beat him .. i doubt u will kill him :)
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691152
you'll blow him away
the only n/a that i've seen that it is remotely comparable to even coming near keeping up with my stock 1997 gtst manual is a honda prelude type r, and even that got a fair caning
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691155
Isnt a full 3' exhaust to big for a N/A 1.8 or 2.2 ??
and skyline will win
VTEC engines require larger then normal exhaust systems. The H22A redlines about about 7600 from memory and has a lot of exhaust gas that needs removing. If he has extractors, there will be no loss of backpressure.
My trueno for example runs 272 degree cams and has a full 2.5 system which allows it to breath at 9500rpm
A lightly modified Vti-R prelude will run 15.2 easily. 100kw's at the wheels with the H22A is easily acquired.
I think it would be close, turbo or no turbo, the H22A has balls of torque.
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691416
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
