If i purchased a stock auto 94 r33 gtst with about 100,000km on da dial and went up against a manual 93 honda integra vtir with a full 3'' exhaust system, air filter, extractors with 180,000km on da dial. i should win right coz i have turbo. dis might sound like a stupid questions but im still new to cars comin from bikes. how would i fare up. would i still rip him or, just, or lose. Newbie needing help.
https://www.sau.com.au/forums/topic/34515-newbie-question/
well u "should" but i wouldnt' think an auto skyline is that great if i were u ... i got one myself ... the loss in power with the auto is too much i think ... but what can u do?? anyways hit the brakes and press the acc and rev it to about 3k just before u let go so u launch at 3k ... anymore and it might be a bit dangerous for the auto trans ... anyways u should beat him .. i doubt u will kill him :)
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691152
you'll blow him away
the only n/a that i've seen that it is remotely comparable to even coming near keeping up with my stock 1997 gtst manual is a honda prelude type r, and even that got a fair caning
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691155
Isnt a full 3' exhaust to big for a N/A 1.8 or 2.2 ??
and skyline will win
VTEC engines require larger then normal exhaust systems. The H22A redlines about about 7600 from memory and has a lot of exhaust gas that needs removing. If he has extractors, there will be no loss of backpressure.
My trueno for example runs 272 degree cams and has a full 2.5 system which allows it to breath at 9500rpm
A lightly modified Vti-R prelude will run 15.2 easily. 100kw's at the wheels with the H22A is easily acquired.
I think it would be close, turbo or no turbo, the H22A has balls of torque.
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691416
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
