If i purchased a stock auto 94 r33 gtst with about 100,000km on da dial and went up against a manual 93 honda integra vtir with a full 3'' exhaust system, air filter, extractors with 180,000km on da dial. i should win right coz i have turbo. dis might sound like a stupid questions but im still new to cars comin from bikes. how would i fare up. would i still rip him or, just, or lose. Newbie needing help.
https://www.sau.com.au/forums/topic/34515-newbie-question/
well u "should" but i wouldnt' think an auto skyline is that great if i were u ... i got one myself ... the loss in power with the auto is too much i think ... but what can u do?? anyways hit the brakes and press the acc and rev it to about 3k just before u let go so u launch at 3k ... anymore and it might be a bit dangerous for the auto trans ... anyways u should beat him .. i doubt u will kill him :)
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691152
you'll blow him away
the only n/a that i've seen that it is remotely comparable to even coming near keeping up with my stock 1997 gtst manual is a honda prelude type r, and even that got a fair caning
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691155
Isnt a full 3' exhaust to big for a N/A 1.8 or 2.2 ??
and skyline will win
VTEC engines require larger then normal exhaust systems. The H22A redlines about about 7600 from memory and has a lot of exhaust gas that needs removing. If he has extractors, there will be no loss of backpressure.
My trueno for example runs 272 degree cams and has a full 2.5 system which allows it to breath at 9500rpm
A lightly modified Vti-R prelude will run 15.2 easily. 100kw's at the wheels with the H22A is easily acquired.
I think it would be close, turbo or no turbo, the H22A has balls of torque.
https://www.sau.com.au/forums/topic/34515-newbie-question/#findComment-691416
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
