Since my car was idling a bit funny, so I took out the AAC value to clean up on the weekend.
and I found out there was no gasket for it, should there be one?
my car is 1997 Stagea series one with rb25det(not NEO).
any help will be much appreciate.
https://www.sau.com.au/forums/topic/345162-aac-value-gasket/
Thank you, guys.
found one for sale on ebay USA, $45 US including postage, good price?
does anyone know where can I find one local and how much?
Sam, $45 for a piece materialof you could get from any Auto shop for $5.Someone may have a valve and could trace a pattern for you.
As i said before a good quality gasket goo will do the job.
Edited by 66yostagea
Hi there, I have an AAC valve gasket that i purchased for my stagea but they got me the one for the Non NEO motor where mine is the NEO, being a differsnt shape. Part number I have on the packet is 23785-57Y00. If someone can FAST your VIN and check that is the correct number for your vehicle, you can PM your details and I will post it tomorrow. Nissan Genuine, still in pack. Not sure how much I paid for it but if you PM me then I will even pay for the postage stamp and being by snail mail, depending on your location from me you will most likely get it early next week.
Dave
Thank you, guys.
Gasket goo should do the trick but if you want genuine, check with some of the forum traders. They get some good prices on gaskets and other consumables, plus you are supporting SAU while you are helping yourself.
an AAC valve for a S2 is just shy of $600 new from nissan, and that was even with trade price, mind you they didn't have any in australia so it had to come from japan. i cant really see much change in price from that for a S1 AAC valve. is your valve stuffed? sourcing a 2nd hand unit from the wreckers will be easier and cheaper.
My post above stated that I had one for a NON NEO motor NEW UNUSED GENUINE. All you had to do was Private Message me your address and I would have sent it AT NO COST. Check my post above and get someone to FAST your VIN and check the part number matches. If you still want it let me know, if not then just use the gasket paper.
thanks, David.
PM sent.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
