all off my series 1 r33, gone to the dark side and bought a s14 lol
all still on car and can be heard or driven, untill parts sell that immobilise vehicle ofcourse!
redcliffe qld
Ph : 0426261146
have a set of tein ha height and damper adjustable coilovers - $900
cusco non sunroof half cage with the rear crossbar will also suit r32 2 door (chromoly = lightweight and sexy as) - $550
cusco front castor arms - $150
boss kit - $40
jjr rear camber arms -$100
ducktail rear wing (painted gunmetal) - $100
nismo 300km/h dash with blue backlighting -$300 ono
Tomei 2-way diff perfect - in housing -$750 just the center - $650
power fc and handcontroller(tuned with mods listed forsale underneath (341.8hp tune) - $1300
660cc sidefeed injectors in factory rail (cannot remember brand) - $450
80mm throttle body - $200
rb25 s1 splitfire coilpacks -$400
front facing plenum (leaked coolant when bought, had repaired daily drove for last year no issues at all) - $200
z32 afm with plug - $250
4 inch HKS exhaust has one hotdog muffler in middle and cannon at the back, very unique nice sound - $300
garrett t04e turbo with the dump/front pipe to suit - $600
stainless low mount exhaust manifold - $100
HID headlight low beam only - $100
3 inch stainless dump pipe to suit standard turbo(turbo to cat) - $80
hicas lock bar - $100
greddy bov with greddy adaptor to suit rb engine - $250
uras drift pinaples . used but like new - $100
https://www.sau.com.au/forums/topic/345170-bens-r33-part-out-sale/
hey im interested in stainless low mount exhaust manifold - $100. what condition is it in??, and has it blowin weld joints before?.. much boost that went through this?. thanx
Front facing plenum (leaked coolant when bought, had repaired daily drove for last year no issues at all) - $200
do you have pics of this? brand?
  • 2 months later...
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
    • Cheers thanks for the help mate I’ll see how we go with that one
