Hi all, just have a few parts leftover from a 32 GTR wreck. Whats listed is all i have so please dont ask if i have anything else...
I'm a little negotiable on price.
Located in SA. Not really too keen on posting things. Contact - via PM.
G force sensor - UNBROKEN! - $150
Clutch and brake pedal - $50
Steering colum, igniton barrel and cover - $70
Air con/heater assembly - $80
Clutch booster/master (vac line has broken off at the elbow) - $60
Dash - Has a bulge but otherwise good - $80
The computers - $50 for all of them
Reverse lamps - $20
Hicas solenoid pack - $40
Unbroken fuse cover - $30
Brake Booster - Some paint is flaking off - $50
A pillar moulds - $60 pair
P/S reservior - $20
A/C compressor - $70
Brake master cylinder, lines and ABS unit - Master cylinder appears to have faulty seal, ABS unit looks good - $100
P/s pump - $50
BOV's - $40
Boot seal - No tears or rips - $50
L and R Front knuckles, hubs, uprights, upper control arms, ABS senders, brake lines, drive shafts (One boot is cracked on both shafts) - $200 for it all
LH tail light - scuffing to the left hand side of the mould. Is repairable. Or just replace the outer skin - $50
RH tail light - Scuffing to RH side of the outer skin. RH lens missing small section of plastic - Useful to someone maybe? - $20
https://www.sau.com.au/forums/topic/345171-r32-gtr-parts-left-over-from-wreck/
Power steering pump be the same as 33gtr?
my Mates is rooted!
If you reckon it will fit I'll take it
pm me some details for pickup bud
thanks
my Mates is rooted!
thanks
I'm not GTR expert, but i'm 99% sure the 32 and 33 GTR pumps are the same.
I'll PM you shortly. I'm replying to PM's as SAU will allow me too. Stupid forum only letting you PM once every half hour... grrrrr
Hi, would you sell the left dash vent separately + post to 2763?
Yes, make an offer worth while and i'll post it. PM me
I will take the P/S reservior.
Give me a price to ship to the gold coast
cheers
Probably $15 champ.
Hya mate how are ya?
Just wondering if the clutch pedal is same as r32 gtst? Also price to ship to Perth WA
cjeers
Not exactly sure mate, i'm not much of an R32 guru. I would say it would be the same but i can't be sure.
Im after the reverse lamps and brake booster. PM me if there still available thanks
PMing.
ok pm your paypal details please I will take that ps resiover
F**k paypal. Bank deposit champ.
I'll PM you when this damn forum will let me! What is it with only being able to send 1 PM every half hour??
BUMP, stuff needs to go people.
Also, sick of time wasters! If you dont really want an item or dont have the cash, please dont waste time contacting me.
  • 3 weeks later...
  • 5 months later...
  • 3 months later...
Bump. Threw half of the stuff out that was quite useless.
Still have whats in the photos.
Price drops;
Clutch and brake pedal - $35
Clutch master and booster - $40
Unbroken fusebox cover - $20
Brake booster - $35
ABS unit/master cylinder - $80
P/S pump and bracket - $40
L/R Front hubs, knuckles, drive shafts, brake lines and upper control arms - $150
Want it all gone! Cheers.
Hey Kitto, the clutch pedals are different between GTR and gtst. GTR is shorter in the section that meets up with the firewall because of the clutch master booster being recessed into the firewall.
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
