Hi Guys,
I'm new to the GTR ownership and just don't really know what's the difference on the stock turbos between R33 GTR and R34 GTR.
I have also heard the R34 twins got ball bearings. What are ball bearings and what are thrust bearings? Does it make any performance/durability difference?
Much appreciated!
For all intents and purposes - the stock turbos are basically the same.
They are both shit, both ceramic, and if they blow with potentially take the motor with them (usually rear that dies)
Is there any difference between the stock turbos and the Nur spec 2 roller bearing turbos?
I have just bought a set of Garrett -7s. Now what?
Pop them in a box and mail them to me.
Or you could take your car to mechanic and ask him nicely if he'll please put them on for you. A fee may or may not be involved.
if you like tinkering with cars, set aside half a day,grab the PDF manual and your new copper washers/ gaskets and tools - then enjoy. (has been documented a number of times and there are things to know about...)
otherwise take it to one of the recommended workshops where they will fit (and probably recommend other things as well), then enjoy 1bar without worries. from there is it time to spend on other mods/ equipment ;)
great choice on the R34 mate :ermm:
Thanks mate. I really think I'm not the man for the job. The car is now at a workshop.
Also what kinda of boost to run on a stock internal with -7? 1? 1.2? 1.5? Any commends really appreciated.
How long is a piece of string!
Depends on engine condition, supporting mods etc.
I'm running 17-18psi nearly maxing out stock fuel system and Airflow meters.
300kw at the rears is what most people get give or take.
Thanks! Can the stock turbos be re-utilized somehow?
Thanks. That's about 1.2 bar.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
