My Dr30 Rs-x
my DR30, nothing much to say, 1983, 4 doors, original throughout, karoism floormats, omoni gauges, and some other old school goodies :D
SPEC LIST -
1983 DR30 RS-TURBO
ENGINE:
FJ20ET (which by the looks has had rocker cover off, and cams installed)
TRUST TD07-25A
HKS cast monifold
HKS external gate
Hyperdrive custom intercooler piping
TRUST Intercooler
TRUST Highmount front pipe
875cc injectors
EFI Hardware fuel rail
Sard fuel pressure regulator
BOSCH 044 fuel pump
PowerFC D-Jetro (s13)
SR20 multicoil wiring harness setup
3 Inch turbo back system
Apexi exhaust valve for quietening the car down when needed
DRIVELINE:
5 Speed manual
Unknown Mechanical Diff (spare diff aswell)
Bridgestone Potenza Shock - Nice firm ride and no leaks
Exedy organic HD clutch
INTERIOR:
Reclinable bucket seat for driver, recaro
RS-TURBO red/black interior
Guages in dash x 4
Personal Steering wheel
PowerFC hand controller
EXTERIOR:
16" Watanabee's.
Pics:
PLEASE EXCUSE MY POOR PHOTOGRAPHY !!!!!
cheers, Derm
Original throughout??? You have the original headlights maybe! The rest of the car appears to be modified throughout.
Don't get the wrong idea, I like the car, I just think it's far... far from original. Like mine!
my DR30, nothing much to say, 1983, 4 doors, original throughout, karoism floormats, omoni gauges, and some other old school goodies :)
Not to bash your car dude, but its not even the original color...
Nice car, ALOT of work, but cant really use the original tag.
PS are you still selling?
S13 dizzy and PowerFC install is not easy, but do-able. Have to use a SR20det wiring loom, adapt to FJ20 power loom, remove FJ20 dizzy guts and replace with a SR20det CAS disk and pickup, then change all sensors over to SR20det sensors, modify throttle body mount to accept SR20det throttle body and TPS, then mount SR20 coils and mody to run high tension leads.
Also i bought this car as a "never registered in Aus" car and done all the work to it and got it complied and registered. Loved the build and the car, and am buying it back now as i regret selling it!
 Share
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
    • Yeh a meagre benefit, what strut tower brace are you using? Eventually all the suspension and tyres are done and you get to ... meagre benefits. Narrow end of the wedge, all that stuff.
    • Yeh not doing anything with spacers at all, ty for the info
    • Indeed. Mitsuoka always did their magic on various Nissan models, but because the Nouera was going to be in the medium sized sedan class, they decided not to try and modify the 2004 P12 Nissan Primera because it looked too modern combined with the 1940's styling. It would contrast way too much so they went with the more suitable CL7 Accord... 😆
