my DR30, nothing much to say, 1983, 4 doors, original throughout, karoism floormats, omoni gauges, and some other old school goodies :D
SPEC LIST -
1983 DR30 RS-TURBO
ENGINE:
FJ20ET (which by the looks has had rocker cover off, and cams installed)
TRUST TD07-25A
HKS cast monifold
HKS external gate
Hyperdrive custom intercooler piping
TRUST Intercooler
TRUST Highmount front pipe
875cc injectors
EFI Hardware fuel rail
Sard fuel pressure regulator
BOSCH 044 fuel pump
PowerFC D-Jetro (s13)
SR20 multicoil wiring harness setup
3 Inch turbo back system
Apexi exhaust valve for quietening the car down when needed
DRIVELINE:
5 Speed manual
Unknown Mechanical Diff (spare diff aswell)
Bridgestone Potenza Shock - Nice firm ride and no leaks
Exedy organic HD clutch
INTERIOR:
Reclinable bucket seat for driver, recaro
RS-TURBO red/black interior
Guages in dash x 4
Personal Steering wheel
PowerFC hand controller
EXTERIOR:
16" Watanabee's.
Pics:
PLEASE EXCUSE MY POOR PHOTOGRAPHY !!!!!
cheers, Derm
https://www.sau.com.au/forums/topic/345181-my-dr30-rs-x/
Original throughout??? You have the original headlights maybe! The rest of the car appears to be modified throughout.
Don't get the wrong idea, I like the car, I just think it's far... far from original. Like mine!
https://www.sau.com.au/forums/topic/345181-my-dr30-rs-x/#findComment-5565825
my DR30, nothing much to say, 1983, 4 doors, original throughout, karoism floormats, omoni gauges, and some other old school goodies :)
Not to bash your car dude, but its not even the original color...
Nice car, ALOT of work, but cant really use the original tag.
PS are you still selling?
https://www.sau.com.au/forums/topic/345181-my-dr30-rs-x/#findComment-5566615
S13 dizzy and PowerFC install is not easy, but do-able. Have to use a SR20det wiring loom, adapt to FJ20 power loom, remove FJ20 dizzy guts and replace with a SR20det CAS disk and pickup, then change all sensors over to SR20det sensors, modify throttle body mount to accept SR20det throttle body and TPS, then mount SR20 coils and mody to run high tension leads.
Also i bought this car as a "never registered in Aus" car and done all the work to it and got it complied and registered. Loved the build and the car, and am buying it back now as i regret selling it!
https://www.sau.com.au/forums/topic/345181-my-dr30-rs-x/#findComment-5586174
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
