bout time I cleaned up the shed....
So up for sale are the following items:
1) Full set (5) of Genuine R33 Floormats, great condition - $150
Parts from a R33 GTR:
2) Front Swaybar with links $50 - upgrade for GTST?
3) Rear swaybar with links $80 - upgrade for GTST?
4) Rear Camber arms $40
5) Castor arms with Nolethane adjustable centres - $80
6) Airbox with K&N panel filter, all clips, and snorkle $150
7) Plastic Recirculation pipe that goes under the radiator - $50
8) Factory BOV's - $100 for both or $60 each - prefer to sell both
9) 3" high flow cat, good condition $100
10) Oval muffler 3"in, 3" out. Straight through, dent on one side, $30
11) RB26 cam cover, painted purple, missing a little paint - $50
12) "drift" gearknob, silver carbon pattern - $30
13) Genuine "GTR" badge for front grille, few stone chips on the red "R" clips intact - $20
14) 2 x 275/35/R18 Toyo R888 - bald - good for track days (0.5 seconds faster around Malalla apparently?) or burnouts? $50 - pick up only
15) Factory Lower intercooler rubber hoses $50 for both
16) Hicas Rack, with tie rods - was working fine - $80
Last but not least
17) Factory Plastic Air Diversion panel for R33 GTR (Very rare to find these days!) - $100
All parts located in Hope Valley SA 5090
Can organise freight at buyer's cost
Will trade/discount for the following items:
Carbon wing blade for R33 GTR
Boot interior clips
400R clear front indicator lense (I only really need 1)
Cheers,
Nigel
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/
Hey mate I have a carbon wing blade fopr 33GTR, just has couple small chips in it but in good condition.....
Im keen on the Air diversion panel and floor mats for a swap..............BUT im located in Brisbane
PM me if your keen and we can nut out deal..
Cheers
Himmy
  • Nope 1
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5562144
Cheers
Himmy
PM sent mate :P
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5562372
On hold for HIMMY
Cheers,
Nigel
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5562394
Whats the air diversion panel?
Pics of that please. Fitted if it still is or dummy fitted.
Thanks
It sits between the base of the grille, and the bonnet latch
However it is on hold for HIMMY
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5563050
hi, im ver interested in the air diversion panel, how much would it be to post to the gold coast 4214??.. thanx.. been after one for a while, but didnt want fibreglass.. :blink: thanx
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5563774
On hold for HIMMY
Cheers,
Nigel
It only fits GTRs, and read above....
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5563835
hi, ill take the air panel.. i know it fits gtr. i have a r33 gtr as well.. :P... hehe.. ill take it if falls through. im ready to pay now :P
Edited by seriesII
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5564565
hi, ill take the air panel.. i know it fits gtr. i have a r33 gtr as well.. :down:... hehe.. ill take it if falls through. im ready to pay now :ph34r:
you have PM.
trade fell though on the floormats, and i have offered the Air diversion panel to seriesII
all items except BOVs and air diversion panel still for sale!
come on guys, make me an offer if you dont like the prices! i dont want to put this stuff in the bin when I move house!
https://www.sau.com.au/forums/topic/345185-r33-gtr-parts/#findComment-5572642
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
