my 93 r33 skyline is for sale m-spec
s1, 75000km, Burgandy, pod filter turbo back exhaust, alarm, aero front bar rego till may 2005
car has been serviced every 4000-5000km
Cluch done 10,000km ago put a heavy duty cluch in.
18,000 ono
call scott on 0433123291
i live on the northern beaches
pics
http://www.zigzig.net/tosh/scottsr33/
https://www.sau.com.au/forums/topic/34520-1993-s1-r33-gts-t-skyline/
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
Ive seen this car, And the owner did tell me he was selling it with a boost guage and turbo timer.
If you want a well looked after daily driver, then I suggest you inspect this car closer.
If your after a threashed drifter, then by pass this car.
Only one drive of this baby and youll know exactly what im talking about.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
