tested amp drain when car is off at 0.95 amps is this normal the car is more track then show and has only minimal sound equipment std. speakers aftermarket deck. It has got a power fc and bosch 044 pump. what could be my problem. i have tried a new battery
any help greatly appreciated and yes i did search and could not find anything about amp draw
start pulling fuses until the draw goes away. that almost looks like a light is on somewhere. if you are working in the boot push the boot catch closed and retest.
normal draw is 20-50mA so 0.02 or 0.05A.
hate it when the volts excape.lol
bet its a bad backup battery in the siren ?? happens after about 2-3 years or more often if you don't drive often or deep cycle the main battery?
or stuck relay ? your sure nothing is wired to be on with the key off ? aftermarket stuff ??
i think this might be the problem however i got all the kickpanel fuses out and its not loosing voltage just got to work out which one it is. car for last 2 year is old a weekender/ fortnight car
well that's easy then.
disconnect negative cable from your battery.
grab a multimeter and set the dial to read Amps - 10A.
clamp one of the multimeter leads to the negative terminal of the battery, and the other lead to the negative cable you disconnected.
Now the circuit is complete, and power is back on.
Your multimeter should be showing you the current drawn from your battery.
So with the car turned off (make sure interior light and boot light are off), start removing one fuse at a time, and check the meter each time to see if the current draw has dropped to acceptable levels. 0.05A or under.
Replace fuse, and pull the next one untill you find the one single fuse that causes the current reading to drop. whatever that fuse powers is the source of your problem.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
