Well ole faithful is on her way out. Everything still works sweet but i have to restart the pc ten times before it boots as i think one of the HDDs are on its way out and its in Raid format.
So i have just ordered a yummy 60Gb Vertex 2 SSD now help me shop for the rest. I have about $800 lads and here is my selection so far:
Ordering most parts now through netplus as its only about 20mins from mine but anything else you would recommend i am all ears, especially the RAM i have no idea on compatability
* Intel i5 760 - $211 - http://www.netplus.com.au/product/CP1/CPIN...ead-Turbo-Boost
* Gigabyte GA-P55A-UD3R P55 MB - $164 -
http://www.netplus.com.au/product/MB2/MBGI...i5-i7-Lynnfield
* 1TB Caviar Black - $104 - http://www.netplus.com.au/product/HD4/HDWE...rd-Drive-1000Gb
* RAM - ??????? no idea but i want 6GB worth to go with Win 7 64B edition - any recommendations around say $140 that is compatable with the MoBb?
Sorry to do this to you all as i hate those "build me a pc thread" but ummm yeah.... i really need your advice regarding the RAM and the mobo as i really have my heart set on the i5760.
Thanks guys!
https://www.sau.com.au/forums/topic/345279-pc-bout-to-die-help-me-shop/
If you are only going for a mild overclock 3.8ghz/air, then any ram honestly around that price will do.
And with that board you can only really go with:
4GB or 8GB (2x2gb or 2x4gb) as its a dual channel, not a triple like the 1366 boards, i5 is 1156
So IMO, 4GB @ $140, you cannot go past the Ripjaws for value, and you get a cooler :blink:
http://www.pccasegear.com/index.php?main_p...oducts_id=15872
Is the ripjaw definately ok with that MB? lots of reviews of people not sure of compatable RAM with Gigabyte 1156 mboards??
I actually have an SSD an OCZ vertex SSD order i just placed with pccasegear about 30mins ago. If it is definately compatible might add it onto the list.
Yeah will do a very mild OC, prob sit at about 3.3 ghz to be honest.
yeah gskill works fine on my GA-P55A-UD4 brah, I got the 1600mhz sticks, n get 8gb not 6 cause of dual channel not triple like said above lol
one other thing, if you get the 1600mhz ram you'll need to use an eXtreme Memory Profile in the BIOS (piss easy) or it will run at 1333mhz
Edited by bozodos
Turning in the XMP profile simply engages the correct RAM settings.
And for overclock of 3.3 simply hard set the voltage to stock and up the BLCK (i think tahts it?)
Don't use the mobo overclock, sometimes voltages go too high for what you need and in turn more heat.
Especially if using the stock cooler
i have a lovely xigmatek red scorpion as my cooler which is quite nice so all ok there.
Looking at this RAM:
http://www.netplus.com.au/product/MY3/MYD3...VR1333D3N9K2/8G
i am getting most of my parts from that store so may aswell go that. Doesnt seem to be the Hyper range of Kingston RAM but should hopefully be ok to clock it to 3.3ghz.
GSkill (pre-date ripsaw / trident) is completely unstable unless it's specific timing is set so the Dominators need to be set a lot lower than they should be for it to work. Otherwise Dominator GTs are flawless (the ones I got back from RMA anyway) with system at 4GHz ram at ~2000.
Edited by DivHunter
Ash XMP also overclocks the processor slightly (well at least for Socket 1156 - mine is 2.88 instead of 2.8, no noticeable difference of course). The GSkill is also reviewed quite well, and is signifigantly cheaper than Corsair (paying for branding IMO).
Thats a fairly cheap price for 8 gigs of RAM btw
Ok so my order that i pick up from Monday is the following:
Online quote from NetPlus Micro Computers
25/11/2010 2:05:26 PM
Product
Code
Qty
Price
SubTotal
Intel Core i5 760 LGA1156 CPU
CPINPCI5-760
1
$211.00
$211.00
MBGIGAP55A-UD3R
1
$164.00
$164.00
4096Mb 4Gb DDR3 1333 Memory KVR1333D3N9/4G 4GB
MYD313-4096K
2
$77.00
$154.00
1Tb WD1002FAEX WD SATA3 HDD
HDWE72RSATBA010E
1
$104.00
$104.00
MS Windows 7 Home Premium
SWMSW7-02HP32
1
$108.00
$108.00
Total Price:
$741.00
all in all i am pretty happy bout it.
8GB ram, i5, 1tB HDD windows 7, my baby will be flying for less than 1k! not too mention my SSD should be arriving any moment now from PCCASEGEAR :-)
Do you guys think the ram will be ok for a mild OC?
you running two different sets of memory you mean?
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
