Hi fellas,
My R33 GTR is currently running LENSO D1R Wheels.
Offsets are 18x8.5 front and 18x10 on the rear.
I recently bought some wheels spacers and they're just wrong. The stud pattern appears to be wrong and is too long so they just won't fit.
Your help urgently would be much appreciated...
Please advise which of the following spacers would fit perfectly? Thank you so much in advance.
http://www.justjap.com/store/home.php?cat=269
Also, is having different size spacers on the rear and front bad or is it still ok? I was thinking of going 20mm at the fronts and 25mm on the rears.
Edited by Spunky Munky
https://www.sau.com.au/forums/topic/345293-r33-wheels-spacers/
Just looking at those spacers, they don't specify Nissan in the suitable vehicles list. Be careful of this, because even if the stud pattern of the spacer is the same as the hub, the hub centre itself may not be...so all the pressure/weight will be on the wheel bolts and spacer bolts instead of the hub centre = not good.
I have JJR spacers.
They are hubcentric so are a perfect fit.
Depending on the width of the spacer used and the recess (if any) between the wheel mounting holes you MAY need to cut your studs shorter.
Most good aftermarket wheels you'll be fine, but my 34R wheels required it.
Hi fellas, thanks for all your help...I really appreciated it...I ended up order 2 pairs from Ebay from some manufacturer based in NZ. Only because these looked more heavy duty and were factory painted black which matched my rims. The JustJap ones look good too but are silver which would stand out and would be a easy target for the cops to defect.
I've opted for more width at the front because I have a staggered offset. I know it's not recommended for GTRs being AWD, but it has not posed any issues for me yet and it's not that I race it at the track or anything so all good so far.
Cheers.
Kevin
I thought all spacers were illegal, but then, I heard new information yesterday that the bolt-on spacers are legal...it's the plates that simply sit on the hub which aren't?
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
