  • Replies 157
Isnt it amazing how xbox owners want to always stand up for their console and defend its purchase! There is a reason a PS3 is more expensive...... Its just better, deal with it.
PS3... IT JUST DOES EVERYTHING.
IPhone 4... IT JUST DOES EVERYTHING, except what you want it to do!
>Your point is invalid as i own both
meh... bought it played it for a bit.
nothing special. what f**ks me off is that you cant even change wheels on "standard" cars and even though they've been transported from gt4 where you could.
like come on, so many years in development and you can only really do the same shit as gt3 to majority of the cars...
game play is pretty similar to gt4.
overall tho its not bad... but nowhere near as good as it should have been.
username speedy_tx3 or skyhi_33 (i cant remember which username is on it atm lol)
Edited by SkyHi_33
so basically... forza 3 is better.
gotcha.
Both different games, different physics and handling.
I own both and enjoy both, GT5 simply for the content and Licences, Forza for the customisation.
Im still a GT fan sine PS1 days, need to buy a wheel though PS3 controller is killing me ><
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
