Still at trying to solve my boost issue.
When you take a STOCK S1 BOV off, should there be no leak if you blow (no sex please) into it, which is SFA pressure. I have two BOVs here and both have a slight leak when shut. Is this normal??????
My prob is that sometimes when slowly accelerating it will boost to 1-3 psi then die inthe arse back to zero boost.If you pull over and try to rev it wants to cough and die, sometimes you can save it, but not always. Turn the key off and it starts Peter Perfect, and runs till next time it spits the dummy.
https://www.sau.com.au/forums/topic/345334-leaking-bov/
The factory BOV is designed to leak slightly at idle.
If you have a pressure source on the top of the BOV identical to the other side it won't open.
Have you got an AFM issue? Poor plug connection, dry/cracked solder internally on the pins?
I had a diagnostic, while driving. AFM,coilpaks, A/F mixture, spark, plugs all checked out OK. I feel i am looking for a leak somewhere.
Stick my head under the bonnet again.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5563651
I should clarify the leak is mostly from that small hole on the face of the BOV to the side of the port.
I figured that out. duh. my bad.
As Mike says it is an air leak and I am pretty sure its coming from where the AAC valve is. The problem now is I will have to take the plenum off to fix it.
To do this properly you need two slabs (at least) and two packs of bandaids. And probably a new plenum gasket.
Two slabs $70, Bandaids $10, gasket $98, total $178, plus extras say $200.
Might as well get the cam covers off and have them polished.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5563786
You could try resoldering the AFM pins. It is about a 30minute job and it might explain why the issue is intermittent. Leaks tend to be constant in my experience.
That is what i cant understand. When the engine is idling you can hear a leak. Rev it a bit and it seems to go away.
Not 100% sure what you mean about resoldering the pins. I can solder tits on the Tin Man so if you give me a pic I can do it.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564221
do you think it could be the noise of the air being sucked through the AAC valve, i can see how it could be mistaken as an air leak, especially since yours in under the intake manifold, kind of tricky to get to and tell for sure.
to solder the air flow meter have a look through this tutorial -link to thread-
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564286
What about getting hold of one of the ECUTalk displays; you can watch AAC and AFM voltage levels and see if anything goes haywire when the car cuts out? It also logs max values too. If it's AFM the AFM value may go either to ~0V or ~5V when the problem occurs.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564358
There is noise from the PCV valve at idle that will disappear when you rev it. Does a FFP have a PCV still attached? I guess they delete it so perhaps not that?!!?
The afm is easy to solder....even I can do it and I am definitely not skilled in that department. The biggest issue is gouging out the silicon as it runs a bit deeper than you think. Once you pop it open the pins often look ok but hit them up anyway.
I have fixed 4 afm's with intermittent issues, stalling, misfires etc. It might be something else in your case but there is little downside in re-soldering.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564380
Yes. The FFP has a dedicated line to the PCV. It could be that. I will have anot6her listen tomorrow.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564643
The cam cover to manifold PCV has a 1 way check valve. When the manifold pressure is less than the cam cover, ie under vacuum, oily gases flow from the cam cover into the manifold. When the manifold pressure is greater than the cam cover, ie under boost, the check valve seals, and any blowby pressure is vented out of the other PCV breather pipe back into the turbo inlet. I think that explains what you want to know?
Edited by zoomzoom
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5564895
Found a leak in the fuel PRV hose. Still hear the noise at the AAC but that could be normal as the hoses and fittings meander a lot.
We had road tested the AFM, A/f ratio and these were normal but the car did not play up while doing it.
After fixing the PRV leak I am sure the running is much smoother.
Test will come when I go on the cruise.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5567411
Back to square one. Yesterday while L plate son driving, engine went into limp??? on the Gateway motorway. Car was running perfect for about 80ks, then poof. Got to the edge of road after cutting across lane. Turned off, started first kick, and ran sweet. On the way back, alone, it tried to limp about 6/7 times but by now I can handle it. But I considered it unsafe to take on the cruise. Bugger.
Fitted another AFM last night and will test over the next two days.
Found a leak where the PCV valve is in the L/H cam cover, but want to check the AFM first. Must do things one at a time otherwise I will not know what is the cause.
https://www.sau.com.au/forums/topic/345334-leaking-bov/#findComment-5569212
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
