post-35466-1290566388_thumb.jpgpost-35466-1290566352_thumb.jpg up for sale is my 180sx it has the following mods
Reason for Selling: put a deposit ona s15
Asking Price: $14,500 ono
Contact Info: pm or text 0432 586 780
92 redtop sr powered 180sx
ALARM and IMMOBALISER
keyless entry
good box
nismo short shifter
nismo 3puk clutch
nismo lightened flywheel
fresh locked diff
will come with stock t25g
splitfire coilpaks
tomei reg
rollin 600x300 fmic
BOV removed
large pod filter
will come with stock seats
stainless radiator overflow
oil catch can/breather setup
full 3" exhaust including stainless dump pipe and hiflow cat through to hks cannon
battery relocated to boot
stock ecu remapped
car could do with a tune but runs fine
new radiator hoses and heater hoses
new vacuum lines
turbosmart boost controller(currently 12psi)
cusco engine damper
Soild diff cradle mounts
whiteline swaybars front and rear
cusco strut braces (front/rear)
d2 coilovers (base height adjustable /damper adjustable)
full r33 rear brake and hub conversion with r33 handbrake cables and new shoes(5 stud)
full gtr front brake upgrade (but currently sitting on s13 nuckles so still 4 stud front end)
new brake pads front /rear
rebuilt calipers front/rear
adjustable castor rods front/rear
adjustable cambertop d2's
under radiator support panel brace(between castor rod mounts)
adjustable camber arms in rear
traction rods in rear
hicas lock eliminator bar
fresh plugs
fresh oil
fresh oil filter
fresh fuel filter
currently sitting on 18 x 9/10" gold drift teks
kumho ecsta ku36 225/40-18 semi slicks (front)
Bridgestone potenza re030 225/40-18(rear)
full blood orange respray
vertex frontbar
skirts and rear bar unknown copies
also have painted uras rear bar that comes down a lil lower
widebody fibreglass front gaurds(30mm)
widebody rear fibreglass overfender(25mm)
rare rear window covers (changes the look completley)
safety 21 6 point cage with padding
monkey cross car brace
nardi classic
quick release detachable steerer hub
stainless switch panel with blitz turbo timer incorperated
pioneer usb input headunit
carbon fibre centre console insert and around stereo etc
carbon fibre arm rest
carbon fibre centre piller covers
dash matt
complete body dynamatted including doors and hatch
xr6 gauge pod with 2 digital calibre gauges(volts and boost)
stainless cluster surround /blue and green dash lights
isotta handbrake cover and issota boot (works well)
vertex gear knob
HID kit installed
sleepy eye conversion
car is setup for drift atm but have full interior that will come with car
car is currently registered and i drive it everyday
theres heaps more that i havnt written.
if u need to know more . just contact me ...
this car gets a huge amount of attention and runs a1 . everythings been done in the last year..
https://www.sau.com.au/forums/topic/345338-nissan-180sx/
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
