Midnight Purple
GTR_34
 Share
Hi guys im thinking bout getting a respray done and I was just wondering is it hard to get this type of paint mixed up?
Also what sort of price am I looking at just for the paint? Few people claim it costs over $1000 per litre, is this true?
Thanks
http://i192.photobucket.com/albums/z30/sne...tepurpleIII.jpg
Edited by GTR_34
the midnight purple on r33 gtr's is quite cheap compared to the price of mp2 and mp3 on r34 gtrs
my painter got a quote for all 3, mp1 was 600 buks for 4L base coat only obviously
900 bucks per L for mp2 and mp3
who knows maybe you can get it cheap via a connection or something but general price to the average joe for mp2 and mp3 is quite high
Edited by snozzle
My "midnight purple" was a mockup paint mix by the looks of things, so when I got a can of touchup matched, it turned out closest to "Honda RP25P Aubergine Pearl Standard" with a touch of some kind of blue....much cheaper lol
I've got a MPIII 34 GTR paintcode LX0
basically it's a dupont chromalusion paint
I have the formula saved somewhere if you would like it.
I did get a quote for 500ml of base and 500ml of topcoat and it came to $1070 with a 6 week lead time as the paint was coming from Dupont Japan
I can remember that most of the price has something to do with a tinter in the topcoat KK700
Here's a pic of My 34 and Choy's 34 shows the difference between MPII and MPIII
Don't have any decent pics as the sun didn't wanna come out.
Getting my car re-sprayed in MP soon too, so a quick question.
The original Midnight Purple as seen on R33 GTRs is just a pearl purple? Where as MP II and MP III are both colours that appear to 'change colour' in varying lights?
I just want to make sure what I think is MP I and what I think is MP II is correct.
I've seen Falcons with just a Purple Pearl in the paint.
My MP R33 GT-R yes, was a Purple Pearl, but quite subtly it also had a touch of dark blue, black and even less so of green in the paint. So in that respect, it's quite noticeably different from the Falcon.
The MP I can look dark blue to black in varying lights too, but much more subtle.
MP II has more green and dark blue than MP I
MP III is a full-on chameleon chromemulsion colour and is very difficult to paint eg. matching up skirts to the rest of the bodywork.
You're pretty much correct.
MP1 is a metallic paint (easy to paint match)
MP2 is a metallic paint with a candy clear (relatively harder to paint match)
MP3 is a habib spec prismatic paint (good luck paint matching it properly on anything other than the assembly line)
factory habib spec yo. ftw.
Hey mate I've replied to your email.
let me know if you didn't get it and i'll post up the paint formula in here..
Noy
Hey mate,
Sorry for the late reply, been really busy with work.
Thank you so much for taking out the time and sending me the formula
Its much appriciated.
Thanks again
Tanveer
for getting a price on paint code you should be able to call any auto paint store and give them the paint code and they will tell you if they can make it and what it costs.............
heres a list of the paint codes for skylines.........
NR32
KH2 - Gun Grey Metallic
KG1 - Jet Silver Metallic
TH1 - Dark Blue Pearl
AH3 - Red Pearl Metallic
732 - Black Pearl Metallic
326 - Cristal White
KL0 - Spark Silver Metallic
BL0 - Greyish Blue Pearl (special order)
AN0 - Wine Red
BCNR33
AN0 - Super Clear Red
BN6 - Deep Marine Blue
KH3 - Black
KL0 - Spark Silver
KN6 - Dark Grey Pearl
LP2 - Midnight Purple
QM1 - White
BT2 - Champion Blue
KP4 - Sonic Silver
AR1 - Super Clear Red II
BNR34
TV2 - Bayside Blue
QM1 - White
KR4 - Sonic Silver
KV2 - Athlete Silver
GV1 - Black Pearl
AR2 - Active Red
EV1 - Lightning Yellow
LV4 - Midnight Purple II
LX0 - Midnight Purple III
WV2 - Sparkling Silver
QX1 - White Pearl
EY0 - Silica Breath
JW0 - Millennium Jade
Alright, next question.
I have the paint and everything for my car, but I have just found a front lip that I really like that I can buy for my car. It comes in either Fibreglass or Carbon Fibre.
Anybody have pictures of carbon fibre on LP2???
  • 1 month later...
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
