I know it has been asked a thousand times before. But I cant find a thread that touches on it.
I have an R32 GTSt and looking at a rear pair of wheels that are 17 x 10" +44. Not sure what the offset limits are for clearing the inner suspension? Anyone? I am not concerned about outer guard, just need to know what sized offsets you can run before you have problems with fouling the shock-suspension etc
https://www.sau.com.au/forums/topic/345454-17-x-10-on-an-r32-gtst/
Hey, I've used this before when working out clearances.
http://www.rimsntires.com/rt_specs.jsp
Dial in the stock wheels, then the new wheels and it calculates how much closer to the guards and inner suspension components rims and tyres end up.
Also useful way of calculating overall tire diameter for different profiles/ widths too.
Thanks, but the problem is the std rims are so small and no real help when trying to work out clearances for a 10" rim. Hopefully somebody has fitted some decent sezied rim AND tyre in the bum and can work out if these +44s will fit. I want to run a 265 rear tyre on the 10" rim
Thanks, I understand that if i go GTR style offsets I will clear the suspension. But I want to use all the available space, so a +22 offset will leave a sea on the inside and cause issues for the guard. I am hoping there is a number around +30 to +44 or something that allows for inner guard clearance
just going off 9s 9.5s I'd say for a 10 inch an offset around +30 would be about right mate. think of a stock 33 GTR wheel which is +30 9 inch. now add half an inch to each side of that and bobs your uncle. maybe a +35 would give a little more guard clearance and still clear the suspension but I dunno about a +44.
The lmgt4's I sold you where 17x9.5 +38 and they were flush with the guard but can't remember if there was clearance on the inside. So I'd agree with above and say go about the +32mm area. 18x10 with +12 stick about 40mm out with 0 camber and 265's
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
