Hey all,
I have for sale a few bits and pieces which i was going to put on my 1993 R33 GTST before i sold it.
All parts are brand new and still in the original boxes which they came in.
I'll be posting pictures later on this afternoon.
- Top Mount Manifold - $200
- Bosch 023 Internal Fuel Pump - $220
- 80mm Throttle Body with manifold - $400
- Garrett GT3082R Turbocharger 600hp - $1700
- Nismo Fuel Pressure Regulator - $100
or i will sell it all together as a package for $2400.
like i mentioned before all parts are brand new in boxes and still sell for the original prices that i paid.
Located in Hackett ACT
Edited by bennybooo
https://www.sau.com.au/forums/topic/345467-brand-new-turbo-upgrade-parts/
Hey all,
location???
All information on the turbo is here. Best price is listed at $1700 and as you can see on tweakit they are still selling for $1815.
http://www.tweakit.net/shop/product_info.p...bmeufviib6ci201
how much for postage to perth for top mount?
what make is top mount?
what postcode in Perth?
The topmount is just a generic brand i got off ebay. one of my friends has one of his R33 and has lasted him years so the quality is high.
BUMP!!
80mm Throttle Body with manifold and Nismo Fuel Pressure Regulator - sold!
make me an offer on the remaining parts!
want them out of storage and being put to good use!
Hey all,
bump price drop!!
- Top Mount Manifold - $150
- Bosch 023 Internal Fuel Pump - $150
- 80mm Throttle Body with manifold - $320
- Garrett GT3082R Turbocharger 600hp - $1650
still open to offers
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
