been reading the hypergear hiflow thread and the hypergear site. im interested in their turbo upgrade for rb25det with the G2 profile. has many people here used one if so what are your thoughts on it. im only looking at running betwee 450hp and 500hp+ what are your thoughts
Do you mean 450-500 engine hp? So 280-300rwkw?
First of all, I would be wary what profile people think they have as a G2 profile wont make over 270-280rwkw. Most people have the G3 profile which is similar to a 3076 in size so can make 280-310rwkw.
I have a G3 profile but in a standard compressor housing and am very happy.
the standard compressor housing is .63 right?
I think you mean exhaust housing. There are two different standard exhaust housings the R33 one and the OP6 one on the R34. Pretty sure its smaller than 0.63.
Mine has a larger 0.82 rear but with a standard compressor cover on the front.
I do think this is all answered in the Hypergear thread.
cheers
Just think about this. Whatever power a hypergear turbo will give you. A Garrett can do it a lot better, less lag and everything. I'm sure I'm not the only one who thinks that "hypergear" talks up these turbos waaaay more than they deserve.
so how many Hks turbos do u own? because its all so been proven that hks do the same thing to garret but your not raging on them.
from what i have seen hypergear are very good for the money
What you talking about. Garrett make turbos for hks. I had a Garrett 3076r. And I've seen hypergears variant which gives the same power... with 1000rpm more lag. Clap clap
yes but under Hks blade designs . and you are not gonna try and tell me that hks don't spool better?
maybe this guy cant afford garret , much like u clearly cant afford HKS
Not true. They are almost identical, new ones with ceramic balls are even better. lol
Yawn, more turbo options for people with different budgets can only be a good thing. I will go call Garrett and see if they can make me a turbo that uses the standard compressor cover makes 280rwkw on 15.8psi and bolts straight up to my standard piping for just over $1k.
If your happy with your turbo enjoy it otherwise it just looks like you are upset with your choice.
I remember seeing your dyno sheet, there are some serious inconsistencies with your speed axis. The dyno shows it coming on boost way before any 3076 on this forum also the dyno stops at a speed that when you transfer to rpm comes out at 6,000rpm. I highly doubt the tuner stopped tuning at 6,000rpm. Dont believe everything you see on a dynosheet.
Possibly run in 3rd gear :)
Hypergears are good, well mines good, had a few problems here and there, but worked out well, been using mine on track and drifting , mines pulling 250kws on 17psi , very good power delivery where are you located? if you wana have a feel of my power pm me you can come past mine bro and il show ya
BAHAHAHAHAHAHAHAHAHA!!! Yup good one, well how come everyone elses GT3076s are so laggy in comparison then?
Also, could you please explain why the tuner would stop tuning at 6,000rpm? Surely something as good as a 'fkn garrett' could perform all the way till 7,000rpm?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
