Hey guys, any opinion or help would be appreciated.
This is a really weird problem and ive never had anything like this, ill take the car out first thing and it will be fine driving for 20 mins + doesnt have a problem, driving hard, driving slow, up hill, down hill doesnt matter.
But its normally the next time i take it out i have the problem.
It will start fine and drive fine but maybe 5 minutes into the drive ill just be driving along steadily at say 60km or 80km and all of a sudden it will start to misfire and almost stall but then it will be fine, then after another few minutes it will do it again and if i come to a small incline it feels like its really struggling and sometimes when i come to a stop it will just completly stop and be very hard to start, but once i get driving again it will be fine???
Mods are standard RB20, 3.5" exhaust from turbo back with high flow cat, Pod filter, FMIC, Alloy radiator, Turbo timer and thats about it.
https://www.sau.com.au/forums/topic/345490-need-help/
Thans for your help mate,
UPDATE!!!
While checking my plugs ive stripped alot of things off cause im going to put my new turbo on while i do all this. Ive noticed im missing atleast 2 exhaust manifold studs and one of my vaccum lines going to the manifold has broken so will also replace all that.
Keep the ideas coming
https://www.sau.com.au/forums/topic/345490-need-help/#findComment-5565696
  • 1 month later...
    • Not that I know from experience, but in theory you'd want your gate spring to be as close to target pressure as possible, so you'd go with the higher gate spring?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
