as above only in vic
cheers
replaced the two long rear lines, replaced handbrake shoes, adjusted from leaver and still handbrake woks like pooo, so this is my last suggestion to my problem. i was going to get brand new lines made up but a second hand one should do.
picture of what i want.
https://www.sau.com.au/forums/topic/345540-wtb-r32-handbrake-setup/
Did you adjust up the pads at the drum?
yes that little flat head screw, did it just so it doesnt touch but still no go. going crazy with this problem.
So you've adjusted the cog behind that screw on the drum and you've adjusted it up at the handle... sounds like you have badly stretched cables... if you get desperate I have a set of cables but I'm in Adelaide... we could work something out if you think you'll get ripped off. PM me if you like
yes adjusted both of them.
yeah as i was taking apart the leaver and whole assembly i noticed the adjusting screw on the leaver was tightened up and couldn't screw anymore so yeah cables are stretched....but i replaced the rear cables already so that leaves the front/leaver cables i need to replace..pic in this thread.
  • 2 months later...
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
