Hey guys
I am buying a CC (greddy style/D1 etc - the square shaped ones) and I want to mount it like Hamish did
(http://www.sau.com.au/forums/topic/129549-oil-catch-can-mounting-and-roughting/page-2?hl=+oil). I will baffle it by putting stainless steel inside. I have 2 questions
1. does it matter where the stainless steel wool/stuff is placed inside the CC?
2. does the hose from the rocker cover have to go to a specific port/hose barb etc on the CC?
Thanks in advance guys
Amir
  • 11 months later...
I have a catch can setup two cam cover hoses straight to catch can and the return back to original return on the turbo inlet. I have notice that i have have massive amount of condensation in my catch can clear water type that has a strong e85 smell i don't have any trace of water in my oil when checking the dip stick and noting to instigate that i have a gasket bypass issue Is this normal or do i need to get it checked out ?
Normal with e85, warm up tune can make a noticeable difference though. You want to get it in closed loop asap after cold start.
Matt
Hi Matt
Anyone you can recommend that i can go to that can do this tune? not sure if i can do it on mine as i am running a Nistune ECU
Anton
Hi Matt
Anton
You need to post up your location in your profile if you want a tuner that is not thousands of miles away.
  • 3 months later...
Running a single turbo on a rb26dett, anyone ever vented the crankcase through the rear turbo oil return. I was thinking about tying it together with the rocker cover breather hoses and then to a catch can and either going to atmosphere or running a hose back to the intake. to create some vacuum in the crankcase. What do you guys think? I'm just wondering if i'd be sucking oil up instead of just pressure.
  • 6 months later...
  • 7 months later...
Does anyone have any drawings or illustrations of what sort of baffling should be inside the catch can for a track setup?
Is it extensive?
A picture would be nice.
Just now, KiwiRS4T said:
Stangely enough Google has heaps. Just Google "baffled catch can design"
I figured i would ask here, as being a GTR owner, getting real world GTR examples that work would be a start :)
    • Nah, apparently the way to do it is just mess with how much timing the engine uses to try to correct idle. So it massively undershoots, then overshoots, then undershoots, then overshoots. So timing is going from 5deg to 45deg to 5 deg to 45deg. But I kinda prefer the car to not lurch around and have a dependable idle. Given it didn't idle for shit and stalled about 7 times on the way home, still yet to drive it for the 2nd time to see if it's fixed.
    • Best chop idle FTW, just add an idle timing hole lol
    • Alright. Many little things have been sorted and the car successfully drove home with an incredibly huge exhaust leak. Unsure if it's simply been awhile, but new heads and cam and intake sound f**kin awesome. It might only be me that notices it though, and it's hard to tell from a 15 minute gauntlet run home and attempting to bleed the radiator. Undertrays on, tools out, road brake pads in, idle un-f***ed, time to do some road tuning. From my commute around town it sounds and drives *really* nice (with a max of like 35% throttle). It'll go to a dyno for a proper before and after once the tune is more roughly dialled in. And @Dose Pipe Sutututu I did learn how to do a proper chop tune at idle. I did indeed even do it, but the car shaking around at idle from the driverr seat made me make it smooth again.. I feared for my engine mounts and clerances to engine bay jank. . After the exhaust is fixed I may mess around with it more. I'm just happy to have it drive around without bucking or stalling which is a WIP.
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
