1 hour ago, GTSBoy said:
And the baffles in a GTR's catch can are different to the ones you would use in a catch can on a Renault 19 how exactly?
Oh I dont know, sizing, design, capacity maybe.......
  • 2 years later...
So after 3 years of this topic being dead im bring it back with the hopes of some further information.
I have a RB30DET with around 350rwkw, have a N1 oil pump and restrictors in the block (no rear head drain and no larger oil gallery drains) I don't intend of pulling the head off any time soon to do modifications.
I have had my PCV blocked off for many years and have both rocket cover breathers Tee'd together and running to a catch can (not baffled, no access for baffling) then to atmosphere. When ever I do one or two decent drag runs I need to empty my catch can which is a pain and generally embarrassing.
After having this setup for about 6 years I've just Decided to tee into my turbo drain pipe which is fine at the moment apart form smoke coming out of my breather.
Now it sounds very similar to what quimby asked and what KiwiRS4t responded.
On 14/12/2015 at 1:12 PM, mayor quimby said:
Running a single turbo on a rb26dett, anyone ever vented the crankcase through the rear turbo oil return. I was thinking about tying it together with the rocker cover breather hoses and then to a catch can and either going to atmosphere or running a hose back to the intake. to create some vacuum in the crankcase. What do you guys think? I'm just wondering if i'd be sucking oil up instead of just pressure.
On 14/12/2015 at 3:19 PM, KiwiRS4T said:
Don't do it. You don't want to interfere with the turbo oil drain. And you want your crankcase/sump breather on the other side of the motor.
Now what is the best way for my to get rid of all this oil? Am I'm plumbed completely wrong? There is too much oil to plumb to intake.
Would a non return valve work on the can drain or would the oils weight not open an inline non return?
I'm after some help.
Thanks
Adrian
Have a look at how the Nismo can is set up.  It drains back through the turbo drain.
To be fair if its for the drags you dont need it to drain quickly. So the answer to your question may be not an nrv but simply a small(er) orifice because who cares if it takes 5 minutes?
But yes a non return valve would work if you could find one you are happy with.  You will to be a bit careful how you mount it (ie vertically of horizontally as they sometimes dont like certain positions) which could be an issue.
But honestly if you are getting large amounts of oil from a single pass you should have a think about venting the sump to the can.
So there you go - four answers to one question.....
Thank you Djr81 for a Much more informative response than the previous. There doesn't seem to be as many setups and issues exactly the same as the ones I have, so trying to find specific answers in the threads hasn't been very successful.
Maybe, but he does have a point.  Venting blowby from the sump and not the head is a better way of doing it and doesnt require the head to be lifted.
The oil puke problem is a common thing for RB's of almost any capacity.  The solution is essentially the same but does vary slightly based on peoples catch can preferences. At the end of the day low blowby plus a way for the blowby to get out of the sump without going through the head is the basis of the solution, as covered in the oil control thread.
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
