Hey guys selling the ceffy, its been an awesome car, an dont want to sell it but its this or my laurel..
so here goes
Nissan Cefiro 145k on clock. 198kw on 12 psi
RB25DET conversion unknown k's. Have receipts from last owner for freshen up
Extreme Brass Button Clutch
Malpassi Fuel Reg
Plazaman Plenum, shorter cooler piping. more response
Screamer Pipe/Dump :-) :-)
Autech Body Kit (not over the top an too big)
Autometer Boost Gauge
Twin Pipes, Hi Flow Cat
Tint
Stereo
Nismo Knob
'Unknown' 2 Way LSD
5 Stud Conversion (approved)
Tein Coilovers (approved with certificate's)
Solid Cradle Bush's
All Electrics Work
has bronze 32 GTST wheels in bronze at the moment.. can negotiate the VIP wheels (17x9, 17x10)
Bad Points:
Roof Starting to fade, can organise to be painted if required
Air con needs gas. all hooked up jus never gassed after 25 conversion
Currently out of rego
No Air Con
OPEN TO SWAPS, bikes, cars etc...
$12kono
Edited by C33Laurel25
https://www.sau.com.au/forums/topic/345548-fsswap-a31-cefiro/
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
