I've decided to strip my first street registered S13 (midnight blue) which is modified with a variety of quality brand name parts. If you want parts don't stuff me around, organise it with me, and put a deposit down otherwise I'm not taking it off the car. I have looked after my S13 very well since I've owned it so all parts are in excellent condition and have travelled very little, unless otherwise stated. LOCATED IN CANBERRA-CAN POST MOST THINGS-
---------CALL OR MSG ME ON 0411 086 883---------
I have tried to list what I have and am willing to sell:
SR20DET with gearbox and all manual conversion gear including the modified loom, ecu, tailshaft, pedals etc-$2600
32 row oil cooler with all braided lines and a TuneAgent adapter plate and a relocated oil filter in awesome condition-$400
S13 space saver (spare wheel from boot looks unused)-$30
Reinforcement bar for the front has been modified to fit front mount-$50
Nismo chrome 10mm screw on type gearknob so won't fall off like cheap ones (JustJap sell for $189)-$70 and it fits skylines, 300zx, 180sx, cefiro, bluebird etc, etc
Smoked tail lights-$170
Bosch 040 fuel pump and cradle-$160
Complete set of boot plastics-$50
Fuel cap lid-$10
Map light-$20
Rear view mirror-$15
Windscreen wiper motor-$25
R180 4.3:1 ratio diff with 6 bolt stub axles-$50
Hybrid front mount intercooler with all piping and clamps perfect condition-$450
GKTECH overflow bottle-$30
GKTECH front pipe-$110
GKTECH catback exhaust-$200
3 inch XFORCE High Flow Cat-$130
Nismo 2 way with 5 bolts stub axles LSD-$800
7" Car DVD, TV, GPS touchscreen with the box in good condition-$300
S15 Seats-$550
C's style short shifter-$110
Digital climate control with loom-$120
Turbo timer-$40
JustJap dished drift steering wheel-$80
GKTECH Boss Kit-$25
Front clear corner indicators (1 small bracket that slides onto the side of the fender are broken on 1 i think but still screws to top of headlights and in good condition on the outside)-$50
Ganadoor style mirrors with cool led indicators that you can wire up as blue, orange, or something else-$70
Front seatbelts in very good condition as I replaced them-The pair for $80
4300K H4 socket 55W HID's (the best visibility)-$90
Front CA18 front bar nothing wrong with it-$110
Rear S13 bar straight as-$100
Front drivers side fender straight as pretty clean with barely no scratches-$100
S13 passenger front fender few small dents-$50
Sunvisors-Both for $20
S13 interior carpet (has hole where drivers feet go)-$50
Rear seatbelts-$70
Rear seats-$40
Centre console (I have two of them with all the switches and ashtray-1 is standard black and the other is white)-$40 each
Stereo surround painted white-$20
Door trims-$50 each
GTR style grille with fresh black paint the best condition I've evr seen-$140
S13 Square (J series) headlights with clear covers perfect condition-$400
Window regulators: Drivers side-$60 Passenger side-$50
Window switches- Drivers side with 1 small chip on the button-$40 Passenger side perfect nick-$30
Drivers side glass with tinted 25% black tint (good quality tint by the way) perfect condition-$60
Passenger side glass (window tint slightly scratched in one area but can't barely notice)-$45
Dash with a few cracks but good condition-$140
Cluster surround-$30
S13 door seal plastic panels-$20 each or $30 pair
SR20DET manual non-abs Tailshaft-$100
2 Federal 595 235/45/17 tyres (done 30kms on them)-$80 each (Will have to confirm about the tyres if someone wants them)
Front SR20DET rotors and calipers (have heaps of meat on them)-$150
Back calipers and rotors-$120
5 bolts drive shafts: $80 for the pair
Work CRKai rims 17x8+32 (only 2 I think)??-$150 each rim few scratches and what not
S13 boot painted matt black spoiler removed and holes filled but will need some more bog a tiny bit-no dents or anything-$60
S13 bonnet in good condition-$200
Doors without regulators and trim in awesome condition-$100 each
I have basically all interior plastics so let me know what ones you need, and I'll give you a price....Will have roof lining and stuff like that out soon (Will let you all know)
I have all adjustable arms, rods, etc, but will inspect them on Saturday and update this list with what I can sell then.
Garrett GT2871R setup (all brand new apart from the turbo which has only done a few thousand k's with literally no shaft play) NOT SPLITTING UP THIS PACKAGE All genuine Nissan parts:
Brand new Nismo 740cc injectors
Brand new Apexi POD filter
Brand new S15 7-Layer exhaust manifold gasket
Clocking adapters for the T25G setup so you don't need to modify cooler piping
Brand new braided turbo lines with fittings
Brand new Nissan 300ZX Air Flow Meter
Brand new Injector O Rings
Brand new Locking tabs
Brand new turbo drump gasket
Brand new oil drain washers I think they are??? Basically everything you need is here apart from the AFM plug which you can buy for $15.
Everything for this package $2300
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
