Hi guys.....had a great week, till this happened on the way home.... Got the furious-horns the rest of the way!
As per title, right side flashes at the correct rate....left fast flashes with no external globe action.
Though I know all globes are fine as they illuminate when alarm goes off.....although they are no longer in sync with each other!...lol..(left to right).....which leads me to think it's more a circuit issue.
Is it a modularised circuit that I, or heaven forbid, Nissan can replace....any ideas?
I don't believe there is a 'flasher-can' as such in these vehicles, and that all 'flashes' are driven by some sort os oscillator circuit..cool.(?)
And that is the part that worries me....how the hell will I fix this thing...lol.
Guys, if you've had this experience before, please do word me up, we don't need this 5hit.
If I can answer anything that could help you to help me....fire away!
Cheers!
indicators are a function of the BCM and the stalk is a function of the cluster and BCM. has anything else quit?
Hi Chris,
mate, from what I can tell it's just the L/H indicators.
If it was the BCM (a module under the dash?), what do you think I'd be up for?
Thanx for response Chris.
thing being it is all interlinked. so whilst it the fault may appear in one spot it will probably lie in another.
as an example:
had a car in here a few days back - no indicators - no dash lighting , cluster worked, engine light on,
AC lost memory. cause - missing fuse in the engine bay.
need to find someone down there that knows late model nissan. they are all similar in design despite the fact that yours is a 'grey' car.
as an example:
Yep, I hear ya!...cwaaaaazzzzy stuff.
..Was always dreading this day, where something stupid would keep the V off the road. (legally anyway).
Car is going to FTG Nissan Monday, they told me they'll be plugging in some diagnostics to check things out.
I'm hoping it's just something simple..it really should be you'd think.(?)
I reckon it could possibly be the alarm install from a couple of years back(???)...was never happy with that....I don't know...we'll see.
Cheer mate.
Having an aftermarket front LEDs as indicators can make the car think thats is a busted glob and it will tell you it's busted by flashing fast on that side.
So it might pay to double check
nope....no LED indicators on my car Paul....(??????????????????????)
Unless someone sneakely snuck some in there?
Cheers.
Cheers.
Hey Chris....seems I was right mate!
The aftermarket alarm was at fault, in focus, the installation thereof.
There are 2 small power diodes (probably of the IN4004 variety) that seclude part of the indicator circuit from the alarm indicator circuit. One had blown, and when the Nissan tech bridged this diode the left hand indicators started working again.
Now there could be long term issues if I continue to run the system in bypassed mode (or maybe there will be no issues), but I will be going back to TOWER AUDIO for the 3rd time with issues on their installation.
The dissing has to go to Tower Audio, as it's the 3rd time in 2 years that stupid things have rendered my car useless, due to their Alarm/install.....I'm farking over it....what next? I expect components to fail, but if you guys could see how crappy the aftermarket wiring around the BCM area is, you'd understand.
Now the KUDOS to Ferntree Gully Nissan......farking heroes in my book....$50 for half hour labour, and honesty....God love 'em!
Cheers!
out of curiosity - who are you dealing with at tower?
Hi Chris....over 6 odd years, all of them?
I'm pretty pissed off with them too mate....I have spent > a couple of thousand dollars with them, and something has always stuffed up, looking back on the work they've done to my cars.
I thought they were the best....ahhh, fark 'em.
so you have spoken to john at moorabbin at some point? he's been doing a few cars for me as of late.
the original owners sold the tower name and opened another shop elsehwhere I'm told.
looks like I should still do a run or two a year down there...
Chris, I just got the V35 back from Ferntree Gully Nissan this arvo, and as I'm working from home at the moment, and not my normal place in Moorabbin, haven't had the chance to go to Tower @ Kilpa Road, (Which I will be doing when back in Moorabbin).
Yes, there is another Tower Audio, just around the corner, more A/V, gizmo type stuff, nice shop, and nice people there.
Wish you could see my TowerAudio wiring job Chris, it's bullshit.
Think I might just solder in a new diode myself, I'd do a better job.
Cheers buddy.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
