Car has problem. Wont start no ignition. Narrowed it down to a Viper Immobiliser which has a constant ticking noise coming from unit. (Sounds like hazards) Up under dash and security blue light constantly flashing.
I have had battery tested twice and said its good. Volts meter says > 12.
Weird thing is it used to start occasionally (example when i cleaned terminals and leads) however would then not start if i left them connected for say more than 1 -2 hours. Tried this now but wont start at all.
I have checked/changed every fuse and relay from fusebox and box near battery.
Car wont jump start. The car will roll start.
I have never needed to use anything for the immobiliser before, however there is a little viper remote (which has never turned on since ive had car)
From what I have read possible reasons are: battery dead, remote battery flat? (like said never had to use it before), key problem? however car used to start off a cut $10 key as well. And internal relay problem in the unit.
If someone has any ideas, had a similar problems or any other suggestions feel free to throw them at me. Thanks
Is this 'ticking' noise happening when your trying to crank it over and/or the light for the immobliser is flashing when you do this?
The ticking noise is constant whenever battery is connected. The light is also flashign whenever connected.
When the car was starting no light and no ticking.
How old is the battery thats currently in the car? Maybe it's not holding a strong charge anymore?
I had a similar issue to you after I got my alarm system + immobliser installed, it sounded almost exactly like your situation however mine only made a ticking noise and the light flickered when you tried to kick the engine over.
I spoke to the technican from the immobliser company as this was like 2 weeks after the install and they immediately diagnoised the fault as being a dead battery. Even though I could turn on my head lights and still get a fair bit of power through the system, with the immobliser installed I needed more power to crank the car over. I think from memory I was told I needed 14V/va.
FYI - We put a larger battery in my car as I still had the standard jap battery in the car and its cranked over fine ever since.
Edited by erderr
the problem is the alarm was reset and lost programming when you changed the battery. the siren sounds like it was shut off with the key on the top of it ???? and the alarm is actually on and going off , but the siren is turned off ??
the noises you hear are the light flasher relay , if its a on off sound, if its a buzzing fast sound the relay is on low voltage or fried. have it checked by viper dealer ?
a dead battery in the backup battery on the siren is possible as well? if it got deep cycled too much and is old they wont hold a decent charge.
and if you don't have the wires connected on the battery right (loose or corroded or even missing one ignition wire/bad grounds ) the viper is sensing the voltage flucuation as a possible attempt to over ride the alarm and disconnect the battery. normal for a decent alarm to do to protect the car from crims?
and if your car alarm was installed by a pro, it should be covered under a brain swap program for warranty for life of the orginal owner ?
12volts on the meter doesnt mean your battery has any current capacity to speak of, I've seen new batteries with 13volts, but very little current holding. wouldn't even turn over a starter. you need to have it load tested to see if it's still good ?
you have a dead battery/cell if it wont hold a charge , wet cell jap batterys are way to small for anything , ditch them asap
you never use the viper remote ??? so the car isn never alarm protected ??????? the remote takes a battery which is most likely dead, either a mini 12v or a 1.5 aaa depending on which model it is. cost a buck or two
always alarm your car, even in your driveway or petrol station , or it will get stolen !!!!!!!!!!!!!!!
There in NO ALARM on the car.
I have never had to arm or disarm or unlock etc. I never had any of this installed was just as it is when I got the car.
Battery was bought new approx 12 months ago.
Car has been off road for nearly 6 months though so has gone flat a few times.
What you said about the light flasher relay sounds to be true.
If the battery is low, or faulty would that cause the relay to go off like it is?
I prefer not to have alarms on cars.
thought you said it had a viper immobolizer in it ? that is a car alarm, more or less!!!
really!!!! huge mistake if you don't run one. drives up the rates of insurance for everyone else when the car gets nicked and written off ?
a normal battery will die on "NO LOAD" just from sitting in a month or less sometimes
the viper has a light flasher relay built in, you should see parking lights flash, if not then I would suss the factory or viper relay/flasher has died. or is now bouncing due to low voltage , or the relay to "Immobolize" the car is stuck(they make the same noise when dead) .(outboard high current bosch relay normally) , about 20 bucks to change roughly.
depends on the model of viper , if its' built into the board or on the wire harness itself.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
