Ok chuckie you can take it confrontationally.
For the rest of the SAU community I am suggesting that if drive was suddenly engaged on a dyno the consequences to life are very high. No driveshaft = no chance.
There has been an incident on a dyno in Sydney where the operator nearly lost a leg when drive suddenly engaged on an R32 GTR years ago. Whilst this might be unlikely, for the 10 minutes it takes to remove the driveshaft it is worth the time.
Driving on the road is a different matter.
Thank`s Wolverine ,i seen few thing`s happen on Dyno`s & never nice, but it`s save as the System is disabled,the shop that did forum members car is happy with this,so iam not sure why your all bagging us about it :unsure: it`s in workshop manual why the negativity :thanks:
Forget it Charles, the idiots who have it stuck in their mind that it is a bad thing will never be convinced.
For the record, a SOLID 4WD light does NOT mean the system is in AIR BLEED mode, it means that you have started to drive with the bleed wire unplugged.. i.e. IT'S AN ERROR
The workshop manual provides TWO methods of putting the car in 2WD mode, one is drop the front prop shaft, the other is the method I have outlined.
The only way the system can engage 4WD again is if you turn the car off.
If you're that scared, then don't do it. Simple. Just don't come on here and bag people that have PROVEN it works.
I read and re-read what I wrote and I just can't find the bit where I said pulling the plug was wrong or would cause damage to the car.
On the other hand I was really pleased to have the information at hand to be able to stick it in 2WD for road use.
Well if you two want to get our knickers in a knot by reading waaay too far into what I wrote there isn't much I can do about that.
Just for the record, if you are putting a car on a two wheel dyno I would strongly suggest removing the front drive shaft. If there is any electronic glitch while the drive shaft is still connected there could be catastrophic consequences.
What is that then?
Honestly, I'm over helping and providing information to people in this section.
From here on, I shall keep everything I learn to myself.
Edited by bubba
Do you really want an explanation??
1. A car running on a dyno at 120km/h with switch disconnected = no problem
2. A car running on a dyno at 120km/h with driveshaft removed = no problem
Electronic glitch occurs perhaps 1/10,000 - 1/1,000,000?? chance and ATESSA re-engages
Case 1 Drive engages and potentially serious injury to operator and car.
Case 2 Zero risk of drive engaging.
It is probably a very low risk but it only takes 5 mins to disengage and bring the risk to zero.
So if you don't want to contribute any more because I agree with you for 99% of what you have said and disagree with you in one minor way then that is your call.
It's not you Wolverine, it's the majority of people in here who are internet warriors just make things so damn hard I cbf dealing with it anymore.
Tim, you know I love you :)
Edited by bubba
Look up high above the kick panel, probably near/behind the bonnet release cable. It's a green socket, white plug, single wire either side.
lachlanw: air bleed mode is simply unplugging the plug and turning the key to ON. If you forget to replug then start the car, as soon as you start moving it will throw up an error (the solid light).
oh my bad . how do you get it in airbleed mode ?
on a slightly related note i just downlaoded the latest version of blazt software which does hicas doignostic and real time display of angles
lol @ your a shit stirer ways lachlan. / thread. I can remember you posting up extensive info on this topic not long ago, i shall search. Havent seen you in here in ages. go back to the wasteland and play with your troll tard buddies. :thumbsup: You usually have some good info to contribute. Blatz software is interesting though.
Edited by dirtyRS4
Thanks for that. I found it. It was wrapped up to one of the wiring harnesses with tape.
I was surprised at how much grip I still had until I really started hooning it. Much opposite lock twirling. Reminded me of a couple of my old skylines n gave me a little smile.
Think I'm gonna fit a switch to it, for occasional sideways fun.
On another slightly different note. Is it worth running it in 2wd mode on my 60 mile run to n from work? Doubtful, but maybe save a little fuel ?
Well Try it & see what you get ,:thumbsup:
agreed, post up the results.
IMO: i think it may be less economic by trying to give you the same power(or more as some said) by putting it all to two wheels.
Just a question; With the gear box being designed for a Manual and not the RWD, would this create any extra clutch wear or gear damage? I know its bad to red line in first in a 4wd, so does this get eliminated by 'f**king off the wire'?
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
