Mine is faster and more economical in RWD.
Think about it.. instead of engaging the clutchpacks to drive the front wheels, the front wheels just become parasitic losses. It's not going to be as efficient as a pure RWD though.
You would also have less wear on clutch components as there is less traction which means less load and less stress. I don't know about the M35's, but I regularly bounce the limiter in 1st in RWD and 4WD and the wagoon is still going strong. It constantly surprises me with the abuse she takes, just laps it up and asks for more!
Our 4WD systems are quite intuitive, while there may be only a 5% split normally, under heavy acceleration and heavy breaking the system will feed more torque to the front. So really, any form of spirited driving is stressing the system.
That said, there is a surprising amount of traction still available in RWD (I do have a fair bit of suspension work though).
Thanks for that. As soon as the snow has gone and the weather improved a little, I'll be trying it out some more.
  • 5 months later...
Can someone put up what it says in the manual word for word on this please? I'm interested in the particulars. I see the basics. Unplug the wire, turn ignition to on (not started), pump the brake 5 times in 10 seconds. But do you have to plug the wire in again before driving or leave it unplugged? Does it need to be done again every time you start the car after turning it off? I'm curious to try this on my series 2 rs4s but want to know the exact details first. Thanks.
pump and go
it resets every time the car is turned off
pump and go
Don't have my car here ATM - is there any reason to suppose this won't work on a S1 C34? Or to put it another way can anyone with a S1 confirm that they have done this successfully?
i reckon it should work cos i think the way the transfer case works the same way (shoves fluid in till the wheels spin the same speed)
only 1 way to find out tho
Sorry the exact title was "tuning in RWD" and it was a few threads down - its now top of the next page.
Yeah I looked at that too. The link in there brings you here. It's like this thread is the centre of the universe and all links lead here. Haha. Thanks anyway mate. Going to give this a shot today.
I feel I must just note to you guys that if you want to drive around in 2WD, you have to START the car and then hit the brake pedal 5 times. If you turn to the key to on and do it, it resets when you then start the car.
did this today to my rs4s 100% works couldnt believe the enjoyment haha... also another thing mine took more then 5 pumps of the brakes just keep doing it till 4WD symbol comes on flashing...
yeah thats what i do
unplug, start the car, pump the pedal till it flashes, then drive sensibly with no wheel spin at all ph34r.gif
It only require 5 pumps but because it's working off the brake light switch (I assume), if you don't take your foor all the way off the pedal it won't register the next pump.
I don't push the pedal all the way either, enough to make the brake lights flick on is all the pump you need.
  • 8 months later...
OK just ripped out the kick panel but couldn't find any such switch/plug. Pulled out a few random plugs (all with more than 1 wire) but no good.
Has anyone managed to do this on a Series 1 C34 and if so where did you find the plug and what were the colours?
In my 260rs it is a 2 wire plug, i think one wire is green and the other is black, just guessing as im 4500km's away from my car
OK and you have a series 1 and it was behind the kick panel and it worked?
Thanks
Bob
Found it !!! small black plug fastened to a bigger loom - plug has single yellow wire with green trace socket has black wire!!!:cheers:
Yep series one, yer wasn't exactly shure of the wire colors but that sounds right, did u test it out?
Yes as above. Can spin the rears now but all I really want it for is when I go to the drags (for the first time) so that I can at least warm up the rears - I am not sure I have enough power to light up all four with 255 wide tyres!
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
